Question about Washburn Music
Wiring diagram for a washburn lyons series electric guitar. Where does the white wire going to the output Jack go
Posted by Papa Bear on
  • Sophia Chamberlain
    Sophia Chamberlain May 21, 2019
    my classmate mAkes $84/hr on the computer. She hAs been fired from work for 5 months but lAst month her pAyment wAs $7000 just working on the computer for A few hours. here's the site to reAd more--->> jobscycle.com
1 Related Answer
Fred Yearian
  • 5603 Answers
SOURCE: need wiring diagram for washburn lyon guitar
Try this site:
http://www.guitarelectronics.com/category/wiringresources/
Find the schematic closely matching the resources of switches, pots, and pickups of your guitar.
Posted on Jun 15, 2010
Washburn mercury series electric serial #6050208 trying to find out what I can about it. Found it in a dumpster dive.
Cameron, nice find. Check the attached links,instruction and guides, you can also Google or Bing search the guitar for more info. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.washburn.com/media/catalogs/pdf/Washburn1993ElectricsCatalog.pdf
Blue Book of Electric Guitar Values ELECTRIC MERCURY SERIES ELECTRIC...
washburn mercury series electric guitar Google Search
WASHBURN MERCURY SERIES guitar list
Jul 08, 2016 | Washburn Music
I need a picture of wiring diagram for volume an tone knobs for a washburn lyon LI15. 4 knobs.
I would imagine it to be similar to this. this is standard wiring for your situation. although you may not have these exact pick-ups. the wiring remains the same. Good luck
May 26, 2015 | Washburn Music
I have picked up a washburn lyon series electric guitar s/n 5062530 stamped on the neck plate what year is it and where is it made
It's probably 1995 Washburn Lyon WE3, the pickup configuration is two single coil pickups. It would be easier to tell if there was a photo available.
Dec 22, 2014 | Washburn Music
I need the wiring diagram .
Just google "washburn wiring diagram" Nice pix come up.
Mar 30, 2011 | Washburn Idol Series WI66PRO Electric...
Need wiring diagram for washburn lyon guitar
Try this site:
Jun 13, 2010 | Washburn X10 Electric Guitar
Lyon by Washburn guitar has severe feedback until we short it out buy running a wire from the plug in port to the chrome bracket that the strings sit on, I believe that there is a ground wire off as there...
It sounds like the grounding/earth wire is off the output socket as you already seem to believe yourself. Depending on the model either take off the back control cover panel or the scratchplate/pickguard and look for a loose wire running from the back of one of the pot cases and connect this back onto the screen connection of the jack socket.
Jul 17, 2009 | Washburn Music
I have a washburn WI 14 guitar and trying to change pickups. the old one is two wire. white and bare. the new one have like 5 wires. anyone replace the pickups in their wI 14?
This is the way most aftermarket pickups are set up. Its to accommodate different wiring setups like coil splitting.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Whether the pickup is a Duncan or not does not make a difference. Make sure you solder the red and white wires together(the ones together in the diagram) and cover the joint with heat shrink or electrical tape.
Jul 01, 2009 | Washburn Wi14 Electric Guitar
Music Logo
233 people viewed this question
Top Washburn Music Experts
Bruce Showalter
Ron Rak
Ron Rak
David Gust
Are you a Washburn Music Expert? Answer questions, earn points and help others
