Question about Boating
My wireless pedal doesn’t sync to motor guide trolling motor. It is brand new
Posted by Darryl Brown on
Steve P
  • Boating Master
  • 3,712 Answers
Brand new... thats why they have warranties
Posted on Dec 15, 2019
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
rockmeister
Rockme
  • 2047 Answers
SOURCE: how do I reverse the
Usually this depends on the model which you have in usee. But here are 2 schematic diagrams maybe they could be of help
Diagram 1
Diagram 2
Please do feel free to request further assistance.
Hope this solution has been helpful?
Posted on Mar 13, 2011
rockmeister
Rockme
  • 2047 Answers
SOURCE: i have a 1997 motor guide wireless 24volt Big
Hello there, as you said the power does not get to the bottom of the motor. The motor could be faulty or just completely bad. First you have to determine that the motor is good until you can determine this it is quite impossible to determine if there can be any fix. Take out the motor and try to power it on its own if it works fine then the problem is not from the motor but most likely the problem is from the motor. Let me know what your findings are. Hoping to hear from you soon. Thank you for visiting FixYa.
Posted on May 29, 2011
Bill Boyd
  • 53813 Answers
SOURCE: bearings for trolling motor shaft?
try a dealer who sells this machine or go on line to the maker and open up the spares section.
Posted on Jun 22, 2013
jsbenson
john Benson
  • 184 Answers
SOURCE: I have a Motor Guide
How does the prop rotate? Is it hard to turn? Have you checked behind the prop for fishing line? Are you getting 24 volts to the motor?
Posted on Jan 01, 2015
When troll motor is switch to mom and pedal engaged motor does not run, but when switched to con it runs in this mode. this problem just started, replaced switch and problem still the same.
I'd be looking at a connection problem AFTER where the pedal connects to the unit. It doesn't take much of a "bridge" to cause an open at the chassis mount OR perhaps in the home unit itself. Since the unit runs when switched to "CON" we can eliminate a power supply issue. I'd be looking for an obvious physical problem such as a cold solder joint. Try cleaning the circuit board with silicone spray (SAFE FOR PLASTICS ONLY!!!) and see if that gives you any joy.
Hope this helps and good luck!
Oct 15, 2011 | Minn Kota Maxxum 55 Freshwater Bow Mount...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
How do i adjust the trolling motor so when the pedal is flush or level the boat is pointing staight?
you have to pull the black gear with the 2 cables on it up off the steel slpine gear, point motor straight, level pedal and reassemble
Nov 28, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn kota trolling motor will turn to the rt. when i push the pedal down to turn to the left it goes half way and stops. the pedal will not go any further
Check for rocks or debris stuck in the pedal....
If not then pull the top cover on the motor and look at the pulley cable drum. Here's a schematic:
Max 55 bowmount
Best of luck!
Mike
Jun 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
Boating Logo
230 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
