Question about Rescue Pack 950 Jump Starter
How do i charge rescue 950 - Rescue Pack 950 Jump Starter
Posted by Kevin McDaniel on
SSN-MM3
    Sergeant:
  • 272 Answers
Http://www.quickcable.com/doclib/rescue950-3000manual.pdf
pg5 of the PDF above, pg 10 of the manual
Recharging
Recharge every 30 days and after each use. Failure to do so will result in possible damage to the internal battery and result in poor performance or failure to work at all.
1. Plug the AC Charging Cord supplied into the 120 Volt-in connection on the back of the Jump Pack.
2. Plug the other end of the cord into a 110/120-volt AC outlet.
3. The Red charging LED light will glow and will remain ON during the charging process When the internal battery is completely full the Green FULL CHARGE LED light on the control panel will turn on automatically. This can take up to 72 hours depending on the condition of your internal battery. You can unplug your AC Charging Cord at this time OR leave it plugged in indefinitely as the CUL™ listed internal charger is float charge equipped to maintain the internal battery
Posted on Jun 06, 2019
Rescue 950 unit does not charge. red led does not come on. Got it for Christmas 2014
is there something on the inside to show that the battery inside the unit is actually connected. you may have to take of ft he back and make sure the connectors to the battery are actually hooked up.
May 02, 2015 | Rescue Pack 950 Jump Starter
Can I charge my TomTom 950 on my i Mac
Go to Tom t and look for mac install dmg
Feb 08, 2015 | Tomtom GO 950 LIVE GPS Receiver
Quick cable rescue pack 950 problem charging battery
Hi likelihood that the SLA battery is cactus, SLA's do not being fully discharged and left that way. you can buy new battery and replace!!
Mar 23, 2014 | Rescue Pack 950 Jump Starter
No charger
A replacement cord for model R-950 can be purchased from shaveroutlet.com at the link below
http://shaveroutlet.com/universal-shaver-cord-coiled-for-most-models-p-268.html
Mar 23, 2014 | Remington Titanium Microflex R-950...
How do you charge a battery in 2009 vstar 950
Remove the seat to get access to the top of the batery. I suggest you consider a trickle charger for your motorycle, with permanently attached leads leading from under the side cover.
Mar 17, 2013 | 2009 Yamaha V Star 950 Tourer
Need thingy that replacement heads & cutter fits into
Remington R 950 replacement heads is Remington SP 19 titanium MicroFlex replacement heads and cutters.
Jan 11, 2009 | Remington Titanium Microflex R-950...
Rescue Pack 950 Jump Starter Logo
199 people viewed this question
Top Quick Cable Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Quick Cable Vehicle Part and Accessory Expert? Answer questions, earn points and help others
