Question about Windchaser Heating & Cooling
SOURCE: Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Posted on Oct 12, 2009
SOURCE: Hi i have Fujitronic FA-1300
Before assuming it needs to be recharged with refrigerant gas, check the following. As all of these things can affect the cooling,
1. Remove and clean the air intake filter.
2. Check exhaust hoses for obstructions.
3, Exhaust hoses may have to much downward droop. Which doesn't allow the air to exhaust as it
should.
4. check for holes or leaks in the exhaust hoses. Repair or replace the hoses as needed.
5. Check the temperature setting on the controls, as it may be set to high.
If none of the above solves the problem, it may need to be recharged with refrigerant gas. hich is best left to the pros.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 24, 2011
Jul 02, 2015 | Heating & Cooling
Sep 07, 2014 | Heating & Cooling
Jun 26, 2014 | Haier 12,000-BTU Commercial Cool Portable...
Aug 23, 2011 | Windchaser Portable Air Conditioner
Jul 13, 2011 | Soleus LX-120 Evaporative Portable Air...
Aug 19, 2010 | Danby DPAC12061 3 in 1 Home Comfort 12,000...
Oct 11, 2009 | Windchaser Portable Air Conditioner
71 people viewed this question
