Question about Danco Home
Installing a danco large acrylic diverter handle
For bathtub
Posted by Susan Smith on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Is this a question?
Posted on May 23, 2019
2 Related Answers
Anonymous
  • 9 Answers
SOURCE: How to modify Danco handles to work on Valley II faucets
Do not modify the handles, just buy the pieces missing. they are available through Danco. Even though i prefer using original parts.
Posted on Feb 21, 2009
Anonymous
SOURCE: Have a moen 2995 bathtub
I can't turn my knob to shower off -can you please explain how to fix it. My e-mail is [email protected]
Posted on Jan 24, 2011
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How do i fox a deep scrape on my fiberglass tub?
A deep scratch on an acrylic bathtub can only be fixed with an acrylic repair kit or call a repairman that can repair the acrylic.
This is a very tricky process and should only be attempted by a qualified repair person.
Rod
US Parts Center
Apr 09, 2014 | Home
The diverted valve will not turn ,it worked when installed but won't turn now .how do I replace the diverted.
The spout unscrews from the wall.Take that part off and bring it to the store to match it.Then just screw the new one on.
May 18, 2011 | Moen 2995 Chateau Three Handle Standard...
My lever on my single handle kohler shower faucet is very, very loose. How do I tighten the lever. I don't see any screws or place for an allen wrench
There should be a screw hidden under a cap. depending on the model/style it may be as small around as a pencil diameter or as large as a half dollar (the larger is most common on acrylic handles) Just gently pry this off and you should find a phillips screw underneath.
Feb 04, 2011 | Home
How to replace all the valves hot ,cold , diverter
If you don't really want to tear into the finished tile, you could repair this units most likely. You will have to shut off the water in the house. Remove all handles. Loosen large nut assembly and unscrew the valve stem. If you remove the valve stems you can purchase the complete assembly at a full service plumbing supply co. If the seats are not removeable, a reseating tool is inexpensive. Replacement knobs are available if they are unsightly. The replacement will require removing tile, drywall, cutting or de-soldering piping. Purchase a new valve and follow directions to install. Home depot sell Price Pfister faucets.
Jul 11, 2010 | Price Pfister Bedford Three Handle...
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Jan 10, 2009 | Plumbing
Home Logo
140 people viewed this question
Top Danco Home Experts
Bill Johnson
Tom Chichester
Are you a Danco Home Expert? Answer questions, earn points and help others
