Question about Zephyr Kitchen Ranges
Why can't I find anyone to service my out of warranty Zephyr ventilation hood?
Posted by Glenn Calabrese on
  • rosa aviles May 17, 2019
    Sorry for the issues of error
rosa aviles
    New Friend:
  • 13 Answers
I would suggest taking the see item number did you have email the company or call them as to how to solve the problem if you're already not done so Ice Cube what can be done also try to find another ventilation Hood it is about the same size
Posted on May 17, 2019
3 Related Answers
Anonymous
  • 1036 Answers
SOURCE: Bulb
Use a large ammount of bluetack on the glass - and wear leather gloves for safety.
Look closely at the replacement bulb to check the type of fitting.
Halogens with point pins pull straight out. Thicker mushroom pins turn anticlockwise before dropping out.
Edison screws obviously unscrew anticlockwise.
If the above method fails for straight pin versions, wrap string around the body of bulb and pull out using string.
Hope this helps
Posted on Jun 11, 2008
Anonymous
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Zephyr Typhoon control panel replacement
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have a Zephyr Hood that the lights do not turn off and the fan will come on randomly. What can I do to fix this?
Contact the maker. That should be covered under a recall or under warranty. Appliances shouldn't start on their own!
https://zephyronline.com/
1helpful
2answers
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
My hood just conked out...no apparent reason and is less than 1 year old.
If it cannot be fixed - too expensive or whatever - consider a replacement from Imperial. This is the only company that offers a 5 year 100% parts and labor warranty with in home service. If an issue in the first five years a technician comes to your home. Plus, they are made in the USA. Here is a link for for information: www.vent4less.com
Regards
Donald
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
3helpful
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
1helpful
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Replace fan/light switch zephyr pyramid range hood
Thanks,
Robert
2answers
Bulb
Hope this helps
How to install the ventless Zephyr ZSA-M90AS
Here is the link that has the rough in you need pls review me. Thanks
http://www.zephyronline.com/docs/brand_essentials/products/manuals/savonaa_manual.pdf
Kitchen Ranges Logo
Top Zephyr Kitchen Ranges Experts
Dale Copeland
Dale Copeland
Vernon Taylor
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
