Question about Pride Mobility Products Casual CL30KD Lift Chair Chestnut
How do you remove the battery cover to test or change the battery on Stannah 600 straight chairlift
Basically how to remove the battery cover I see no screws
Posted by Ikram Ghaly on
2000 harley road king starter removal
FOR REMOVAL:
First remove the seat. THEN unthread the bolt and remove the black battery negative cable from the battery negative (-) terminal. THEN remove the primary chaincase cover. THEN bend the tab on the lockplate away from the head of the jackshaft bolt. THEN while holding the pinion gear to prevent rotation, remove the jackshaft bolt with the lockplate and thrust washer. THEN from the right side of motorcycle, remove the starter front mounting screw with lockwasher. THEN remove the rear mounting screw with lockwasher (and the battery negative cable ring terminal). THEN remove the Keps nut from the stud of the bracket tab and remove the exhaust support bracket. THEN pull back rubber the boot and remove the flange nut from the starter post. THEN remove the main power and battery positive cable ring terminals from the starter post. THEN depress the external latch and pull the solenoid connector from the top of the starter housing. THEN locate the oil filler plug/dipstick on the right side of the motorcycle at the top of the transmission case. To remove the oil filler plug pull steadily while moving the plug back and forth. THEN remove the starter from the right side of the motorcycle, carefully sliding it through the space between the exhaust pipe and side cover. (If necessary, remove the allen screw and decorative chrome cover to facilitate starter removal.) THEN, if necessary remove the coupling from the starter motor output shaft, if necessary.
BEFORE starter disassembly, perform all bench tests on the assembled starter.
Basically reinstall in reverse order.
Sep 06, 2014 | Motorcycles
How do i replace hoveround motor?
First off, are you sure it's the motor causing the problem? Changing the motor is a major job. Basically, you have to completely disassemble the entire unit.
Remove the seat and then the batteries. To get to the drive motor, you must remove the pedestal base, and the plastic shroud that covers the base plate. Remove all screws from the top of the unit, and flip over and remove the bolts from the bottom. The control box is held in place by 2 hex screws. Label the motor wires showing their location. Remove motor and replace with new drive motor. Attach motor wires and reassemble entire unit.
Aug 31, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
How do i remove starter from a harley 1340 evo.
If it is a 2004:
First remove the seat. THEN unthread the bolt and remove the black battery negative cable from the battery negative (-) terminal. THEN remove the primary chaincase cover. THEN bend thetab on the lockplate away from the head of the jackshaft bolt. THEN while holding the pinion gear to prevent rotation, remove the jackshaft bolt with the lockplate and thrust washer. THEN from the right side of motorcycle, remove the starter front mounting screw with lockwasher. THEN Remove the rear mounting screw with lockwasher (and the battery negative cable ring terminal). THEN remove the Keps nut from the stud of the bracket tab and remove the exhaust support bracket. THEN pull back rubber the boot and remove the flange nut from the starter post. THEN remove the main power and battery positive cable ring terminals from the starter post. THEN depress the external latch and pull the solenoid connector from the top of the starter housing. THEN locate the oil filler plug/dipstick on the right side of the motorcycle at the top of the transmission case. To remove the oil filler plug pull steadily while moving the plug back and forth. THEN remove the starter from the right side of the motorcycle, carefully sliding it through the space between the exhaust pipe and side cover. (If necessary, remove the allen screw and decorative chrome cover to facilitate starter removal.) THEN, if necessary remove the coupling from the starter motor output shaft, if necessary.
May 15, 2014 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
How to change battery in a gateway zx4931
The real key to disassembly of the zx4931 is taking the stand off. This is basically a large silver rod, and you'll need to remove it. Start by removing the two plastic covers where the stand attaches to the body of the computer. Press against the narrow portion at the square end of the little cover. This will clear the square-end latch, and you'll then be able to work the cover free.
Once you've taken off the two stand-attachment covers, remove the stand, by unscrewing the three screws at each attachment point.
Now you should be able to separate the black back plastic cover. You may need to run a credit card or screwdriver along the silver edge; in the case of this zx4931 all I had to do was tug gently along the edge to separate it.
Now you're almost in. There are two screws toward what is normally the top of the computer that attach a metal cover over the main workings. With the unit face-down on the table, remove these two screws, then slide the metal cover towards the (normal) top of the computer. That's it! You're in. By the way, those same two screws also hold the hard drive in place.then you will inside battery round as big as quarter coin replace it
Feb 17, 2014 | Computers & Internet
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Need to fix the fan on cq50 115nr. Can't find a manual to take laptop apart. Never done it before
Unless you get the factory service manual for the laptop you won't find any printed instructions. You can try searching youtube for instructions.
Basically what you need to do is remove the screws on the bottom of the laptop. Beware that there are usually screws under the covers for the hard drive and memory and such. Also there are usually screws under the CD drive which has to be removed before the top cover can be removed. Most times it is favorable to remove the monitor by removing the hinge screws and wires from the main board. Also note that all the plastic covers also have snaps so some force must be used to separate the covers.
Best of luck, Jim
May 12, 2011 | Computers & Internet
How do you change the CMOS Battery? Acer Ferrari 4000. We can not find any info on how to locate the battery
hello
first remove the power cord, then the battery.
go to this link and download the manual for the Acer notebook.. basically you have to remove the back cover , the one with most of the screws around it. Once you get the plastic cover off, you will see the one side of the mainboard, look for a coin shaped silver battery, remove the CMOS battery and replace with new one
in case yopu dont have the manual, link below can be downloaded -- but it will not show you how to remove the battery.
http://www.acer.ca/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3751&sp=page15e&ctx2.c2att1=27&miu10ekcond13.attN2B2F2EEF=3751&CountryISOCtxParam=CA&ctx1.att21k=1&CRC=719687231
Nov 12, 2010 | Acer Ferrari 4000 Laptop Notebook
I would like to disasemble my laptops hinges but dont know how
What is the Model Series number?
There is a slight difference between the ZV6000, and ZX5000/ZV5000 series, for this procedure.
I want to give you the link to the Service Manual, (Free)
It won't describe, or illustrate the entire procedure of removing the Hinges, but will help for me to guide you.
The basic procedure is to remove all electrical sources first.
AC adapter (Charger), and Battery. Work on a table.
Follow Anti-Static Precautions before you begin.
Have a multi-compartment container, for the various screws you will remove, and label each compartment for where the screws came from.
(You can use a clean egg carton in a pinch)
Open the laptop, remove the Strip Cover,
(Below the LCD screen, and above the Keyboard. There are screws to remove from the bottom, so that the Strip Cover can be removed)
The Strip Cover will be popped up, and out, and there is a procedure for this.
(Start at one end, work your way along, basically)
The Keyboard is removed next. There is a procedure so you don't break the tiny keyboard connection cable.
There is a Thermal Cover to remove.
Next are the Wireless Antenna cables, and Display cable.
There may also be a Display Ground cable.
Screw covers for the hinges are removed from the back. The hinge screws are removed next.
The above is a General, Basic, set of procedures.
Advise do not follow it.
It's just to give you a basic idea of what is entailed.
If your problem Does Not relate to the HP Pavilion ZV6000, ZX5000, or ZV5000 series of laptops, state what laptop manufacturer, and model series it is.
(State in a Comment)
Jul 02, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
TI BA II battery change How do I do this without ruining the calculator!
Turn off the calculator and turn it over with the back facing you. Using a small Phillips screwdriver, remove the four screws from the back cover. Carefully pry off the back cover. Using a small Phillips screwdriver, remove the screws from the metal battery cover and lift the cover off the battery. Tip the calculator slightly to remove the battery. Caution: Avoid contact with other calculator components. Install the new battery with the positive sign (+) sign down (not showing). Replace the battery cover and the screws that hold it in place. Align the screw holes in the back cover with those in the calculator, then snap the back cover onto the calculator. Replace the screws.
The battery is a CR2032.
May 26, 2010 | Texas Instruments BA-II Plus Calculator
Fan blade noise
This is most of the time due to excessive dust covered on processor heat sink try cleaning in side with pressure air by removing keyboard.
Mar 13, 2009 | Acer Aspire 5050 Notebook
Pride Mobility Products Casual CL30KD Lift Chair Chestnut  Logo
103 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
