Question about Dryers
How to i get broken hanger piece out of the lint collector area
Posted by Ondine Arrow on
Kyle DeLory
    New Friend:
  • 18 Answers
Depending on the type of dryer you have if the lint filter is on the top of the machine you can take the back off with 6-8 screws usually 1/4 inch or 5/16 and then the lint area can be accessed by removing 3-4 screws and then you can clean everything out of it which will make your dryer perform better while using less electricity. On a front load where the lint filter is inside door there is usually 2 screws on the front and then 3-5 screws from the inside they are hard to see and usually covered with lint once out you can get the frame work out of the way giving you much more room to get things that are currently stuck or just beyond your reach out of there
Posted on May 18, 2019
  • Kyle DeLory
    Kyle DeLory May 18, 2019
Jim Hicks
    Master:
  • 661 Answers
My lint screen comes out to clean. to clean dust below the screen [before the 4 inch vent tube] i use my vacuum by
adding a cardboard tube [from empty paper towel roll]. i flatten most of the cardboard tube so i can stick it down into the narrow opening.. also a longer empty wrapping paper tube might work. another option is to use a metal flexible mechanic's tool [from dollar stores] - about 3 feet long by 3/8 inch thick with 4 wire fingers that push out the end using the spring loaded plunger. yes, have one but haven't needed to use it for dryer [yet].. ;-))
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: Whirlpool Clean Touch Model LGL88580000
You can check for suction by pulling out the lint screen and holding a piece of paper over it while the dryer is running. If there is suction then it all works correctly. If there is no suction, then there is a clog somewhere inside. You can clear the clog with a long bottle brush or with an attachment from a vacuum cleaner to get inside. If all looks good and still no lint on the screen, the screen may be too short for the dryer and could be a wrong screen for it.
Posted on Dec 18, 2007
Anonymous
  • 9 Answers
SOURCE: Check vent/lint indicator alert
Contact Miele 1800-999-1360 for a new blower fan
Posted on Aug 22, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: lint collector clip is broken and wont
I could list a BUNCH of lint collector clips here but... if you enter you model number on this page
http://www.repairclinic.com/Appliance-Parts?s=t-mdg5500aww-%3d%3di2681p
Where it says
"Enter part or model number for best results"
You should find your lint collector clip.
You can also go to this site:
http://www.appliancepartspros.com/
Again you will need your model number.
Thanks for using FixYa.
Kelly
Posted on Mar 06, 2010
bonedivers
Steve Newton
  • 1140 Answers
SOURCE: A sponge fell in the
Take of vent pipe in the rear, should be able to get it from there.
Posted on Dec 15, 2010
Ryan Miller
SOURCE: Is there a way to access the area under the
I have successfully taken the front of that off and cleaned it out. However, it isn't easy and I could see where it may result in a broken lint catch if not careful. After taking the front panel off - which is a pain in and of itself - you will need to carefully go around the lint catcher and separate it. It is in two halves that are held together by catches all around.
Posted on Nov 15, 2011
Is there a way to access the area under the removable lint catcher or should I just use a hanger
Sep 25, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Duet f70 erroe
An F70 error is indicating that an overheating condition has been sensed.
Causes:
1. Lint build up at the outside wall vent flapper (Clean and Vac)
2. Lint build up in the dryer ducting (Clean and Vac)
3, Poor Air Flow through the dryer due to a blower wheel problem. (Broken blower wheel fins or the venter hub fails causing the blow wheel not to turn at full speed.
4. Lint filter is clogged with fabric sheet particulate. Wash it with vinegar and water and then soap and water.
5. Lint filter cavity is full of lint. Use a folded wire coat hanger to reach the inaccesable areas to dislodge lint build up.
This error is always caused by poor air flow. The dryer vent external connection should push a relaxed hand gently away from the dryer vent connection of the dryer. If you do not have this type of air flow you need to find out why.
Thanks for choosing FixYa,
Kelly
Sep 17, 2011 | Whirlpool Dryers
Lint collector clip is broken and wont hold.onto the back...where can I get a new one?
Where it says
Kelly
Mar 01, 2010 | Dryers
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Water dripping out of the freezer onto kitchen floor i removed back panel in freezer and drip collector under coils overflowing
You will need to unclog this drain with a small flexible drain cleaner, you may be able to use a small piece of a coat hanger, and push the debris through
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
Jun 07, 2009 | Miele T9820 Gas Dryer
Lint Filter Light comes on and cycle is interupted
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Feb 09, 2009 | Kenmore 62622 Electric Dryer
Dec 18, 2007 | Whirlpool LGQ9858P Gas Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
