Question about Sunbeam Heating & Cooling
I HAVE A DUAL CONTROL SUNBEAM BLANKET 85KQP GIVES A FF ERROR ON THE SCREEN OF BOTH CONTROLS AND I DO NOT HAVE THE INSTRUCTIONS TO RESET THE CONTROLS. SOMEONE WHO CAN HELP WITH THE PROBLEM THANKYOU
Posted by Luis Gonzales on
Raj Patel
    Genius:
  • 1,041 Answers
Try unplugging the power cord from the wall socket and check that the connection to the blanket is good and not loose. Then plug back into the wall socket and switch on. If error still occurs then there may be a problem with the blanket.
Posted on May 17, 2019
5 Related Answers
Anonymous
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
woodzowl307
  • 667 Answers
SOURCE: my sunbeam electric blanket - the heat controller ...
do away with the blanket, as it is an electrical issue, hazard!
Posted on May 22, 2010
Anonymous
  • 276 Answers
SOURCE: I have a Sunbeam Queen washable electric Blanket
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $64.00 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Posted on May 26, 2010
Carlos Solas
  • 293 Answers
SOURCE: dreamland electric blanket model 972A1
Hi and thank you for using fixya:
Please check the little fuse. and also check if the resistance is getting red hot?
thanks
Posted on Oct 25, 2010
Anonymous
SOURCE: sunbeam electric blanket flashing ff
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
Posted on Nov 21, 2010
I have a sunbeam electric blanket and a code of f-2 keeps coming on. Is the blanket bad
1.) Follow the instructions on the flag tag attached to the control cord to reset control.
2.) Check the blanket/mattress pad for visual damage.
3.) If no visual damage is found, unplug the system from wall outlet.
4.) Check that the control is well-connected to the module.
5.) Plug the power cord into the wall outlet.
6.) Set the control to "On".
7.) If the system does not operate after 2 or 3 times trying to reset, disconnect the power cord and contact Sunbeam Consumer Care.
Nov 01, 2017 | Sunbeam Heating & Cooling
Our dual control Sunbeam electric blanket is 3 months old and is not heating up, however the powere is on both controls
Should have warranty, plug and unplug the connection to blanket several times. if no help call their customer service. You may be able to return it to the store you bought it from and get a replacement. Hopefully, you still have receipt.
Feb 28, 2015 | Sunbeam Electric Blanket Dual-Controller -...
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
Dual control electric blanket doesn't get warm, the controllers just blink
The problem can be caused by a defective heating element in the blanket.
Nov 24, 2013 | Sunbeam Electric Blanket Dual Controller...
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Jun 25, 2011 | Vacuums
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
I have a Sunbeam Queen washable electric Blanket dual control model BL445D. One of the detachable controls is not working and I would like to buy a replacement one? can you tell me where I can find one...
May 26, 2010 | Sunbeam Heating & Cooling
One of the controls will not turn on. The cord is
Try swapping the controls and see if the problem stays with the control or the blanket side. In any case I would go on line and contact Sunbeam, they are a very reputable manufacturer and I would be surprised if they do not stand behind the product. You will be able to tell them if it is the control or blanket. If the other side of the blanket gets warm when you switch the controls it is the control if the same side gets warm it is the blanket. If neither side gets warm is is the blanket and control.
Good Luck,
Gilshultz
Dec 03, 2009 | Sunbeam SG7621SP Grill
Heating & Cooling Logo
70 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
