Question about Turbo Air Refrigerators
I have a Turbo Air TGF-9F, a single compartment top slide freezer. Picture a rectangle, the right side keeps frozen (frost on the walls) and left is room temp not trying to get cold. Any Solutions?
If you look at the walls, the exact median point of the unit you can see frozen/ice on the right and room temp on the left. Any idea how to get the "broken" side to cool or explain why the vast difference of temperature exactly at the median point?
Raj Patel
    Genius:
  • 1,041 Answers
Could be blocked by ice formation. Leave switched off for a few hours with the door open to allow to defrost.
Posted on May 17, 2019
Testimonial: "already defrosted and took out all ice. when started up again only one side gets cold."
5 Related Answers
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Posted on Mar 30, 2008
robert samples
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
22yooper
James Helmer
  • 828 Answers
SOURCE: Black Maytag Side by Side MSD2756AEB 7+ yrs old? Won't stay cold...
Your condenser where the heat is removed from the refrigeration system may be plugged with dust. The condenser is more than likely located in back of the refrigerator behind a removable panel. Remove the panel and clean it out. Reinstall the panel after you have cleaned the condenser.
Check the back wall of the freezer for frost buildup. If there is frost buildup on the back wall it indicates that there is a problem in the defrost circuit.
Note: The proper term is "More mature individual" , not old.
Posted on Jun 01, 2008
Anonymous
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Posted on Apr 27, 2010
Testimonial: "Excellent Diagnosis. Lower Defrost Heater Failed."
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Freezer cold and fan running. Refrigerator side not cold, no cold air circulation. Wife says sound of refrigerator is lower pitch like something that used to be running is no longer running. Is there...
Hello Otis,
Thier is only one fan in the freezer that circulates the air throughout both ref/freezer. I dont know if ya have a side by side or if freezer on top..but if side by side one possible cause would be the damper in the upper left corner of the refrig. compartment is stuck closed so no air can enter ref.compartment(no damper if freezer on top or even if older model side by side) on either model also even if freezer on the bottom, another possible thing is frost has built up in the freezer and the coil in freezer is a huge block of frost and no air can poass through it because its totally frozen.
Let me know which might be the problem and i will help ya check that EI..is the damper stuck..is it all frosted up and ya can see frost on back plate of freezer wall ect ect..
Gene
Aug 23, 2011 | Refrigerators
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig stopped cooling. Light works, freezer works, can hear freezer fan. Doesnt seem like air flow is getting to fresh food area. Freezer back wall has thin line of frost on it. Model tbx18ja. I want to...
Easiest way is to push against the vertical portion of the ice tray holder until it slides
off the buttons which are inserted into the top of the freezer compartment.
These models sometimes had issues with defrost timers (which I just replaced one today) and Defrost termination thermostats (which is clipped on to a tube behind freezer panel).
Make sure the freezer coils are not frozen up solid, if so use a hair dryer to defrost them
and make sure the vent is not iced over.
Model and serial are in the lower compartment on the left wall. In case you need to go to
the appliance parts store.
Hope this helps.
Aug 02, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Reading error code ER 1F on refrigerator
thats a communication error between the ice room fan and the control board. if you pull the freezer door out and look at the back wall on the left side. you'll see the indent for the ice room fan. its probably frozen. you can unplug the fridge and use a hair dryer to blow heat directly on fan for about 20-30 min. then plug fridge back in. if that does't clear the code. then you're going to have to replace the fan.
Jul 16, 2011 | Refrigerators
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I...
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Mar 21, 2011 | LG LFX23961ST Stainless Steel Bottom...
I have a side by side GE unit. The bottom of the freezer compartment keeps the food frozen but the upper half of the freezer will not freeze. There is a motor or a fan running on the freezer side and frost...
Try to defrost the freezer and see if the air valve opens and closes properly if all of that works then there is a problem with the fan that moves the cold air into the refirgerator
Mar 06, 2011 | GE Freezers
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
Freezer compartment has ice while refrigerator compartment not cooling
the freezer blows cold air into the fridge section and then it returns,first open the freezer door,do you hear the fan blowing,if not you could have a bad evap fan motor,next from the bottom remove the second bin or draw and put your hand on the back wall,is there like snow or ice on the back wall,if so you have a defrost problem,you could have a bad timer,thermostat or a bad heater,also check the packages and the shelves,if you see frozen water droplets the door was left open and the air ducts are frozen up and the cold air can't be blown over to the fridge side.get back to me and tell me what you find and i can help you figure out what's happening
Sep 22, 2010 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
75 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
Lawrence Oravetz
john h
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
