Question about Timex Watches
I don't know what size battery I need for Pooh timex watch model t84851
Posted by Marlene Johnson on
5 Related Answers
Anonymous
SOURCE: Timex Expedition watch
I bought this for my son and he has been living with it for 4 months, and hour and ten min. off !  I just want to set the time, and I'm at the top of the world, no radio shack down the road.  Turn right at the polar bear.
Posted on Oct 14, 2007
Harry Aghyarian
SOURCE: need to know how to calibrate timex e-instruments tide temp #153
i need calibrate my tissot T Touch
Posted on Jun 04, 2009
Anonymous
SOURCE: Timex WR 100 M Model. Sports watch. Need new strap
Not getting any help as promised; just hits to make me pay money. Please cease & desist. I want no further mail from you. I thought it was a friendly chat line to offer advice. It's not. Go away!
Posted on Feb 02, 2010
Anonymous
SOURCE: Timex Sleek stopped beeping when I replaced the battery
I had this problem. I simply flipped the metal plate on the back 180 degrees.
I noticed on the inside of the metal plate a pad about the size of the battery, and guessed from the other notes that this must perform some kind of insulating function. Furthermore, the writing on the outside of the metal plate was not oriented "up"... that is if I was holding the watch in front of me like I was reading it, the writing on the back plate was upside down. Both of these clues led me to believe that the plate had been re-installed wrong. Flipping it around fixed (restored) the beep.
Posted on Feb 07, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: need a glass for my timex expedition watch. What
No problem with it. Any watch repair shop will order exact size glass for your watch and will fit it. Fitting is easy if you have special glass fitting press. No way to replace watch glass without this tool. Visit your nearest watch repair shop and ask for new glass. Rate me,plz.
Posted on Feb 18, 2010
What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
you will need to send the watch off to Timex [email protected]
May 09, 2017 | Timex Watches
What is Indiglo battery
If you don't know what size battery you need, you can find this information on the back plate of your watch. All Indiglo watches have it stamped there, you may need a magnifying glass to read it though!
Jan 04, 2014 | Timex Indiglo Watches
Hello. I own a 40 to 50 year old "Timex Electronic" watch. There is a number date at the 3 o'clock position. I see no other identifying info on the outside. I don't have a battery for it. How
What is the exact model of the watch. I have several Timex Electronic watches that might fit your description. If you pop the caseback do you see the old battery inside? Most batteries would have a reference like: CR2016.
Jan 06, 2013 | Timex Watches
I have a Timex Indiglo digital watch. How do I shut off the hourly signal? Thanks.
may i know the model no. of your watch because there are some Timex watches that don't have the settings to turn off the hourlybeep.
Sep 10, 2011 | Timex Watches
Instructions for Timex CR 2016 748 L8 (Wanted)
Hi m_cox840,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
Aug 13, 2011 | Timex Mid Size Sports 1440 Coach Black...
I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Watches
I have an older timex mens wrist watch and I would like to know where I can look to find the model number on it. It is a wind not battery powered. Thank you for your help.
mcdevito75 here, I just took a peak into my own Older Timex watch, even though it"s a ladies the model number was on the movement itself and only a 3 digit number. Since the older Timex watches were mass produced this is all you may have as far as serial numbers go, and Timex did all their own watches so a serial number may only be 3--4--5 digits long. Anyway, double check the entire watch with a magnifier glass for the serial number, then check inside the back cover and movement itself. Here is Timex contact info, 800-448-4639 if needed.
Aug 11, 2010 | Timex Watches
Need a watch band for model 746 timex digital watch
I would suggest going to walmart or a jewelry store. Walmart has lots of different styles, materials, and sizes of watch bands. They will usually put the band on and fit it to your wrist size.
Aug 30, 2008 | Timex Watches
Watches Logo
121 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
steve
Are you a Timex Watch Expert? Answer questions, earn points and help others
