Question about Jacuzzi Home
2007 Jacuzzi J355 will not heat - Jacuzzi Home
Posted by kim cam on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
If there is power to the unit, most likely it will need to be replaced. Check for reset button, and check the fuses before replacing the unit.
Posted on May 23, 2019
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
Jacuzzi hot tub, Water is too hot. Heats until it trips the system. I have replaced the analog temperature control,
1) Safety question first
Why hasn't the GFCI tripped.
If your spa is not protected by ground fault., then you are at serious personal risk.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
2) Replace the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) If element is cracked, it can continue heating to ground wire, causing runaway heating.
This applies to spas, and water heaters of all type.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 08, 2012 | Jacuzzi Pool & Spa
My jacuzzi is in lock out mode and cant remember how to get it out of that mode
normally this depends on top side layout but on most models you press HEAT button then LIGHT or HEAT then BLOWER.
Nov 24, 2010 | Jacuzzi Pool & Spa
We have a hot tub or jacuzzi inside or on the side of our pool. We had a new heater installed. The jacuzzi should heat up very quickly but now the pool tech claims the drain from the jacuzzi is blocked,...
Is the equipment to heat and filter the hot tub separate from the pool equipment or do both bodies of water share a common heater and filter pump? In most cases they share a pump and heater with valves that direct the flow of water depending on how the pool owner wants to use the pools.
The first thing you need to determine then is if the equipment is working properly. Is there flow of water to and from the spa? If so, is the heater burner kicking on? If it is running, is it running properly with sufficient gas pressure, 3-4" tall bright blue flames and stays on continuously during the heating cycle for the spa?
What is 'very quickly' for the time to heat the water? In other words, if everything appears to be operating normally but the water is not warming fast enough or at all how much time is elapsing before deciding the heater is not working?
How old is this equipment and how much experience do you have with this pool tech or the company they are from?
Nov 07, 2010 | Jacuzzi Pool & Spa
The water will not heat up. How can I trouble
the last time I looked at heaters for jacuzzi tubs they are designed to keep the water at the temperature you filled the tub and not heat up the water from cold to hot.
Apr 04, 2010 | Jacuzzi Home
Jacuzzi is hot heating
TIME TO BUY A NEW COMPLETE PUMP !! I RECOMMEND A STA-RITE DURA GLASS PARTS FOR THE JACUZZI ARE HARD TO FIND AND $$$ SCRAP IT REMEMBER TO PRIME YOUR NEW PUMP ... THUMBS UP IF I WAS OF HELP.. THANKS JAY.. THE POOL PUMP REPAIR GUY
Apr 03, 2010 | Jacuzzi Cyget In Ground Pool Pumps
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Home Logo
151 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
