Washing Machines Logo
Question about Admiral Washing Machines
How do I remove the lint filter inside the agitator of an Admiral ATW4475VQO Washer?
Posted by Mick Shayne on
5 Related Answers
Anonymous
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
Anonymous
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
Anonymous
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
Anonymous
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Posted on Dec 09, 2009
Anonymous
  • 159 Answers
SOURCE: Where is the lint filter located on this washer?HLP21N
Hi.It may be that these machines dont actually have a lint filter,they are making alot of them without lint filters now days.There would be a button trap down at the side or the rear i would imagine for cleaning out debris such as coins,hair pins,Etc.
Posted on May 29, 2010
Testimonial: "Thanks!I will check it out."
1helpful
2answers
Admiral washer atw4470tq0 lint issues on clothes
clean the lint filter in the machine
remove any tissues and papers from pockets before washing
Does the Whirlpool, top loading lsr6332kq1 have a lint filter?
I will suggest you steps to check whether your washing machine has a lint filter. Follow the instructions below.
1)Turn off the washing machine and open the lid or door if you have a front-loading appliance.
2)Place your hand on the upper lip of a front-loading or top-loading washer tub and feel around the circumference for a flat tab. Pull out this tab, which is the handle for the lint filter. If you cannot find a tab on a top-loading washer, continue troubleshooting.
3)Unscrew the cap on the top of the agitator in a top-loading washer. The agitator is the center cone inside the appliance.
4)Pull the lint filter out of the agitator and rinse under cold, running water to clean.
5)Slide the filter into position as far as it will go. Replace the agitator cap if your appliance uses a lint filter in the agitator.
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
1helpful
Washer leaving alot of lint on clothes
THE ONLY FILTERS YOUR WASHER HAS ARE LOCATED UNDERNEATH THE AGITATOR. REMOVE THE AGITATOR CAP AND TAKE OUT THE 7/16 BOLT DOWN IN THERE AND PULL THE WHOLE AGITATOR OUT. IN THE TUB YOU'LL SEE FOUR FILTERS AROUND THE AGITATOR SHAFT ASSEMBLY THOSE ARE THE ONLY FILTERS YOUR WASHER HAS. OTHER THAN THAT IT IS NOT THE WASHER CAUSING THIS PROBLEM. WHEN YOU WASH CLOTHES IF YOU CANNOT SEE THEM GOING DOWN IN THE TUB BY THE AGITATOR AND OTHERS COMING BACK UP ALONG THE OUTTER EDGE THEN YOU ARE OVERLOADING THE WASHER. HOPE THIS HELPS YOU.
1helpful
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Washing machine
Sounds like the agitator securing bolt is missing and what you see is the remaining washer (" a plate with a hole in"), if the bolt is missing the agitator should simply lift up to remove, the securing bolt is a 10mm x 40mm should do the job, you will need a 17mm socket and long extension to refit the securing bolt.
Top Admiral Washing Machines Experts
Marvin
Marvin
Steve
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
