Question about Electronics - Others
What does the code AC 3 mean when appearing on the digital display of my Predator 3500 Inverter?
Posted by John Rob on
Lawrence Lewis
    Habit-Forming:
    New Friend:
  • 65 Answers
Alternating current 3 phase....
Posted on May 28, 2019
Predator 3500 inverter generator. can i splice the 120v outlets to produce 240v
Nothing indicates that you can get 240 volts from the Predator. Buy a transformer or an inverter capable for 240.
Aug 21, 2018 | Electrical Supplies
Predator 3500 inverter starts but no power
Fuse? If fine then open up unit and check components. First for anything spotted visually like burnt/shorted components and any solder cracks on the board from heat.
Jun 10, 2018 | Electrical Supplies
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
Cobra 1500w inverter runs for 4 min. and then shuts off with the code OPC.
Hi
Is the code OCP?
If it is not the code appearing in the display, then it is not a user code but O does refer to an over tollerance situation and L refers to an under tollerance situation can you clarify?
Oct 30, 2013 | Cobra Electronics 1500 Watt Triple-Outlet...
What do you have to push after you have put code into radio on a 2000 vw beetle? Its in safe mode
Hello! 1
When the word "SAFE" appears on the radio display when you turn the radio on, it means the radio will only work once you enter the correct code. Find the code in the instruction booklet that came with your vehicle: it should be on the Radio Card, next to the table of contents.
Press the "MODE" and "SCAN" buttons simultaneously and hold them until "1000" appears on the radio display. Release the buttons as soon as this number appears.
Refer to your Radio Card and use the station buttons ("1", "2", "3" and "4") to input the code. Use the "1" button to input the first digit of the code, the "2" button to input the second digit, and so on.
When the code appears on the display, press the "MODE" and "SCAN" buttons simultaneously and hold them until "SAFE" appears on the radio display. Release the buttons as soon as this appears.
5
A frequency will appear on the display, and you can use the radio again.
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 18, 2012 | Car Audio & Video
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
1998 kia carnival, radio is not working, display shows ''CODE''
I have a manual for a '99 model - the one with separate radio/cassette and CD model No's;
OK55Y 66 860
OK55L 66 860
OK55D 66 860
3K55L 66 860
2K55D 66 860
3K55Y 66 860
Under "How to enter your password"
1. press power button & "Test" appears for 5 seconds, and blinks for 5 minutes. If you turn the power button off then back on again within 5 minutes "Code" blinks on the display.
2. enter password using the numbered buttons - press button 1 once to let it know it's the first digit, then press button 1 again however many times to bring up the code for the first digit. Press button 2 to let it know it's the second digit, then again however many times....etc. To enter default 1111 code, press button 1 twice,, 2 twice, 3 twice then 4 twice.
3. when all four digits entered (default is 1111) press SEL button and display should say "GOOD"
4.You get three goes, if still wrong after third attempt "HOLD" then you have to leave it for an hour
May 02, 2009 | Kia Sedona Cars & Trucks
Electronics - Others Logo
177 people viewed this question
Top Electronics - Others Experts
Tom Chichester
ray gallant
Are you an Electronics - Other Expert? Answer questions, earn points and help others
