Question about Pool & Spa
The dr says iam low on sodium he says just use more salt on my food is there another way to increase my sodium ? What cause a Peterson to be low on sodium where is it going
Posted by Carol Fredrickson on
3 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have 3,000 ppm of
3000 ppm
= 3.53 g/litre
heatman101
Posted on May 04, 2011
Testimonial: "Thank you for your promt responce,"
walker_bobby
Bobby Walker
  • 13 Answers
SOURCE: The temperature in the fride increasing
There should be a Default button on the front of your unit press it and hold it down for about five seconds. this should put your unit back to its Factory settings.
Posted on Jul 04, 2011
gregandjoann
Bean and Bean
  • 64 Answers
SOURCE: low blood sodium symptons
Please go to this link on the Mayo clinic website. They have good advice. I hope you are feeling better soon:
http://www.mayoclinic.org/diseases-conditions/hyponatremia/basics/causes/con-20031445
Here is part of the information they have:
Sodium plays a key role in your body. It helps maintain normal blood pressure, supports the work of your nerves and muscles, and regulates your body's fluid balance.
A normal sodium level is between 135 and 145 milliequivalents per liter (mEq/L) of sodium. Hyponatremia occurs when the sodium in your blood falls below 135 mEq/L.
Many possible conditions and lifestyle factors can lead to hyponatremia, including:
  • Certain medications. Some medications, such as some water pills (diuretics), antidepressants and pain medications, can cause you to go to the bathroom and empty your bladder or perspire more than normal.
  • Heart, kidney and liver problems. Congestive heart failure and certain diseases affecting the kidneys or liver can cause fluids to accumulate in your body, which dilutes the sodium in your body, lowering the overall level.
  • Syndrome of inappropriate anti-diuretic hormone (SIADH).In this condition, high levels of the anti-diuretic hormone (ADH) are produced, causing your body to retain water instead of excreting it normally.
  • Chronic, severe vomiting or diarrhea. This causes your body to lose fluids and electrolytes, such as sodium.
  • Drinking too much water. Because you lose sodium through sweat, drinking too much water during endurance activities, such as marathons and triathlons, can dilute the sodium content of your blood. Drinking too much water at other times can also cause low sodium.
  • Dehydration. Taking in too little fluid can also be a problem. If you get dehydrated, your body loses fluids and electrolytes.
  • Hormonal changes. Adrenal gland insufficiency (Addison's disease) affects your adrenal glands' ability to produce hormones that help maintain your body's balance of sodium, potassium and water. Low levels of thyroid hormone also can cause a low blood-sodium level.
  • The recreational **** *******. This amphetamine increases the risk of severe and even fatal cases of hyponatremia.
Posted on Apr 28, 2016
Should you avoid salt if you have high cholesterol
Yes. Increased sodium in your blood stream causes the kidneys to struggle with removing water from your system and in turn, raises your blood pressure.
Oct 02, 2018 | Health & Beauty
How to control blood pressure?
If you've been diagnosed with high blood pressure, you might be worried about taking medication to bring your numbers down.
Lifestyle plays an important role in treating your high blood pressure. If you successfully control your blood pressure with a healthy lifestyle, you might avoid, delay or reduce the need for medication.
Here are 10 lifestyle changes you can make to lower your blood pressure and keep it down.
1. Lose extra pounds and watch your waistlineBlood pressure often increases as weight increases. Being overweight also can cause disrupted breathing while you sleep (sleep apnea), which further raises your blood pressure.
Weight loss is one of the most effective lifestyle changes for controlling blood pressure. Losing just 10 pounds (4.5 kilograms) can help reduce your blood pressure.
Besides shedding pounds, you generally should also keep an eye on your waistline. Carrying too much weight around your waist can put you at greater risk of high blood pressure.
In general:
Men are at risk if their waist measurement is greater than 40 inches (102 centimeters).Women are at risk if their waist measurement is greater than 35 inches (89 centimeters).These numbers vary among ethnic groups. Ask your doctor about a healthy waist measurement for you.
2. Exercise regularlyRegular physical activity - at least 30 minutes most days of the week - can lower your blood pressure by 4 to 9 millimeters of mercury (mm Hg). It's important to be consistent because if you stop exercising, your blood pressure can rise again.
If you have slightly high blood pressure (prehypertension), exercise can help you avoid developing full-blown hypertension. If you already have hypertension, regular physical activity can bring your blood pressure down to safer levels.
The best types of exercise for lowering blood pressure include walking, jogging, cycling, swimming or dancing. Strength training also can help reduce blood pressure. Talk to your doctor about developing an exercise program.
3. Eat a healthy dietEating a diet that is rich in whole grains, fruits, vegetables and low-fat dairy products and skimps on saturated fat and cholesterol can lower your blood pressure by up to 14 mm Hg. This eating plan is known as the Dietary Approaches to Stop Hypertension (DASH) diet.
It isn't easy to change your eating habits, but with these tips, you can adopt a healthy diet:
Keep a food diary. Writing down what you eat, even for just a week, can shed surprising light on your true eating habits. Monitor what you eat, how much, when and why.Consider boosting potassium. Potassium can lessen the effects of sodium on blood pressure. The best source of potassium is food, such as fruits and vegetables, rather than supplements. Talk to your doctor about the potassium level that's best for you.Be a smart shopper. Read food labels when you shop and stick to your healthy-eating plan when you're dining out, too.4. Reduce sodium in your dietEven a small reduction in the sodium in your diet can reduce blood pressure by 2 to 8 mm Hg.
The effect of sodium intake on blood pressure varies among groups of people. In general, limit sodium to less than 2,300 milligrams (mg) a day or less. However, a lower sodium intake - 1,500 mg a day or less - is appropriate for people with greater salt sensitivity, including:
African-AmericansAnyone age 51 or olderAnyone diagnosed with high blood pressure, diabetes or chronic kidney diseaseTo decrease sodium in your diet, consider these tips:
Read food labels. If possible, choose low-sodium alternatives of the foods and beverages you normally buy.Eat fewer processed foods. Only a small amount of sodium occurs naturally in foods. Most sodium is added during processing.Don't add salt. Just 1 level teaspoon of salt has 2,300 mg of sodium. Use herbs or spices to add flavor to your food.Ease into it. If you don't feel you can drastically reduce the sodium in your diet suddenly, cut back gradually. Your palate will adjust over time.5. Limit the amount of alcohol you drinkAlcohol can be both good and bad for your health. In small amounts, it can potentially lower your blood pressure by 2 to 4 mm Hg.
But that protective effect is lost if you drink too much alcohol - generally more than one drink a day for women and for men older than age 65, or more than two a day for men age 65 and younger. One drink equals 12 ounces of beer, five ounces of wine or 1.5 ounces of 80-proof liquor.
Drinking more than moderate amounts of alcohol can actually raise blood pressure by several points. It can also reduce the effectiveness of blood pressure medications.
http://meditreatsold.blogspot.com/
Aug 22, 2016 | Health & Beauty
Low blood sodium symptons
Apr 28, 2016 | The Health & Beauty
Low blood sodium levels symptoms
sodium is a necessary electrolyte, electrolyte imbalance will cause many uncomfortable symptoms... Pounding heart, fatigue, confusion, and a craving for salty foods (if you didn't have that already.)
Apr 28, 2016 | Health-O-Meter Health & Beauty
What is a salt
From Wikipedia, the free encyclopedia
This article is about common table salt. For salts in chemistry, see Salt (chemistry). For other uses, see Salt (disambiguation).
Salt deposits beside the Dead Sea. Common salt is a mineral substance composed primarily of sodium chloride (NaCl), a chemical compound belonging to the larger class of ionic salts; salt in its natural form as a crystalline mineral is known as rock salt or halite. Salt is present in vast quantities in the sea where it is the main mineral constituent, with the open ocean having about 35 grams (1.2 oz) of solids per litre, a salinity of 3.5%. Salt is essential for animal life, and saltiness is one of the basic human tastes. The tissues of animals contain larger quantities of salt than do plant tissues; therefore the typical diets of nomads who subsist on their flocks and herds require little or no added salt, whereas cereal-based diets require supplementation. Salt is one of the oldest and most ubiquitous of food seasonings, and salting is an important method of food preservation.
Some of the earliest evidence of salt processing dates back to around 6,000 years ago, when people living in Romania were boiling spring water to extract the salts; a saltworks in China has been found which dates to approximately the same period. Salt was prized by the ancient Hebrews, the Greeks, the Romans, the Byzantines, the Hittites and the Egyptians. Salt became an important article of trade and was transported by boat across the Mediterranean Sea, along specially built salt roads, and across the Sahara in camel caravans. The scarcity and universal need for salt has led nations to go to war over salt and use it to raise tax revenues. Salt is also used in religious ceremonies and has other cultural significance.
Salt is produced from salt mines or by the evaporation of seawater or mineral-rich spring water in shallow pools. Its major industrial products are caustic soda and chlorine, and it is used in many industrial processes and in the manufacture of polyvinyl chloride, plastics, paper pulp and many other products. Of the annual production of around two hundred million tonnes of salt, only about 6% is used for human consumption; other uses include water conditioning processes, de-icing highways and agricultural use. Edible salt is sold in forms such as sea salt and table salt which usually contains an anti-caking agent and may be iodised to prevent iodine deficiency. As well as its use in cooking and at the table, salt is present in many processed foods. Too much sodium in the diet raises blood pressure and may increase the risk of heart attacks and strokes. The World Health Organization recommends that adults should consume less than 2,000 mg of sodium which is equivalent to 5 grams of salt per day.
Jun 10, 2014 | Measuring Tools & Sensors
My pool is definatly oversalted but the pump keeps showing low salt. When tested it shows no chlorine. Is this two diferent problems or all related to the same and how do i fix it?
Low salt alarm also comes from having the electrolytic cells "dirty" of calcium/sodium build up.. Check and soak/clean with vinegar.. Shold solve the low salt alarm.. Hope this helps???
Aug 05, 2011 | Intex Automatic Salt Water System for ...
I Have a Easy Set Pool 15X36, And a Salt Water Generator How much Salt do I add for the first Time?
The Compupool CPSC/CPA Series is recommended to run at a salt concentration of 3500 ppm. If you are not installing a Compupool unit, check your manufacturer's instructions for their recommended level of concentration . Use a salt that is at least 99.8% pure NaCl. The preferred salt is an evaporated, granulated, food quality, NON-iodized salt. Avoid using salt with anti-caking agents like sodium ferrocyanide, also known as yellow YPS (prussiate of soda. These cause some discoloration of fittings and pool surface finishes. DO NOT use calcium chloride.
Using a salt water test strip, measure the current salt level of your pool. For the Compupool generators, ideal is 3500 ppm. If the level is low, determine the number of gallons in your pool and add salt according to the Salt Table. For example, if your pool has 15,000 gals of water and your current salt level is 2500, you need to add 125 lbs of salt.
Jun 08, 2011 | Sport & Outdoor - Others
The pool is still cloudy even with all chemicals balanced and a clean filter? I tried the clarifier stuff too and its still like chalky. How can i get it crystal clean?
Follow these steps ... let the CL go to zero ... add a sequestering agent to get the metal out. Follow container instructions ... run the filter 24/7 (deferring to the instructions on the sequestering agent.) When the metal is out, get your calcium to 300 ppm, get your alk to 100, get your cyanuratic acid to 70 - 90 ppm, get your pH to 7.2/7.4 and introduce 2 to 4 ppm of CL. Do this in this order over the course of 2 days. Dont dump all this stuff in at once and expect good results.
If Cal is more than 300 ppm, dump some water and add new. What is the Cal level in your fill water? Be aware of that number as you adjust.
Use Sodium Bi Carb to increase your Alk
Use Sodium Carb to increase your pH
Use dry or liquid acid to reduce Alk and/or pH as necessary
Get the Alk set first before you try to adj the pH.
The Cyanuric acid will protect your CL from the sun.
You cannot run your filter too long! Backweash only when the pressure raises 10 lbs from the new fresh startup pressure. Doing so before is wasteful of chemical and defeats the filter process.
If you are using salt, get the water as I said before you turn on the salt cell. Add salt per instructions on the bag. Use pool/food grade salt only!
I hope you find these comments helpful.
Thanks for your interest in FixYa.com
Jul 31, 2010 | Intex 2500 Above Ground Swimming Pool...
Pool & Spa Logo
110 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
