Question about Sony Bravia KLV 32V300A Multisystem LCD TV
I have sony bravia klv-32v300a blinks 11 times
    Top Expert:
  • Sony Master
  • 76,352 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" of your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}
Posted on May 17, 2019
2 Related Answers
Willie Howell
  • 1030 Answers
SOURCE: 3 blinks sony bravia klv 32v300a
3 blinks ussally is an indication of a loose lamp door
Posted on Feb 02, 2011
specialistel
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
Sony bravia klv 24ex430 red light blinking 2 times?
KLV-24 EX430
RM-GA022
Troubleshooting
3-3. Standby Led Blinking
3-3-1. 2-times Led blinking
2 times Blinking
Check DC voltage at
JL6023
Is it 18V 19 5V?
Yes Change
- 19.5V? B*board
No
Take out adaptor
and test at adaptor Yes
output is it 18V - 19.5V?
Change
B*board
No
Change
adaptor this is flow chart for 2 blink
Aug 13, 2017 | Sony Televison & Video
Sony bravia tv
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Sony Bravia KLV 32V300A Multisystem LCD TV
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Please provide SONY BRAVIA KLV 46X200A red standby led blinking error code meanings
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 04, 2014 | Televison & Video
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
Mar 09, 2011 | Sony Televison & Video
Jan 10, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia KLV 32V300A Multisystem LCD TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
