Question about Mercury Boating
43-828073A1 reverse gear set for marine outboard merc cruiser leg. What year or type is this marine mercury cruiser leg
Posted by Brian Rushton on
4 Related Answers
Anonymous
  • 375 Answers
SOURCE: foward and reverse lever stiff
sounds like transmission problems
Posted on Aug 03, 2008
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
SOURCE: 20hp redline mercury outboard how to take apart the leg
Please Send Me The Serial No
Posted on Apr 03, 2013
jerry howell
  • 183 Answers
SOURCE: 45 hp mercury mariner outboard motor wont go into
will probably need a manual on your motor for this problem. perhaps careful disassembly will reveal the problem.
Posted on Jun 05, 2014
How do you remove the propshaft on a mercury 200 optimax once you have everything off the shaft
go google and type in-- workshop manual for mercury optimax outboard-- there is apage mercury- marine.servicemanualvault.com
which sows manual in pdf form for $4.95 a down load
run through the pages to find the transmission section and if it suits what you want , down load it and have a manual for all the items you need to do
talk with a mercury service shop and get the details of how to do it
I'm sure that you have to remove the leg from the power head so that you can get the selection lever free from the forward/ reverse dog before that gears will come out of the case
Apr 24, 2016 | Mercury Cars & Trucks
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
131 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
