Question about Frigidaire Refrigerators
Frigidaire refrigerator top freezer - how to switch doors from left - opening to right - opening.
Posted by Bruce Lyon on
David Spradling
    Top Expert:
  • Frigidaire Master
  • 11,347 Answers
Change hinges to other side and handles
Posted on Apr 16, 2020
5 Related Answers
Anonymous
SOURCE: Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
Posted on May 27, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Putting refrigerator lock on freezer door
he may have punctured a freon line you will know for sure if it stops cooling.
Posted on Jan 31, 2009
dragonsthatk
albert getty
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
Anonymous
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
Mainetech
  • 37 Answers
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Posted on Sep 02, 2009
How do I turn demo mode off on FGHS2631SS Frigidaire?
Are you sure you have the right model #? Your refrigerator's model number may vary by type. The model number of a top freezer refrigerator can be seen along the upper left side wall of the fresh food compartment and is visible when the door is opened. The model number of a french door and side-by-side refrigerator can be seen along the upper right side of the fresh food compartment and is visible when the door is opened. model-number-refrigerators.png
Sep 10, 2014 | Refrigerators
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Cannot attach toe plate
Hello - To remove the toe grille you will need to have the doors of the refrigerator open, the grille simply snaps into place. Remove the right side first and then the left, as the water line is on that side. When replacing follow the steps in reverse.
Nov 04, 2012 | Frigidaire FRT21H8 Top Freezer...
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
Jul 24, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Need to turn doors around , doors are opening to left side..need to open to right side
Good day,
Start from the top and work down.
Make sure all items are removed from both doors, and machine should be shut off.
1. Remove top bracket with the freezer door still shut.
With both hands, open freezer door about 1 foot, and lift off.
All thru this process keep track of all shims and washers and their location.
2. Remove center bracket holding main door and remove using the same process as with the freezer door.
3. Remove bracket from the bottom and reverse to the other side.
There will be a lot of press in buttons to be removed by prying them out with a small screw driver.
4. Reinstall in reverse order, making sure all shims and washers go back where they came from. As well, Tighten screws while making sure the door is in alignment at the same time.
5. Remove both door handles and reinstall. Some screws may be hidden by a cover that will have to be pried away first.
Nov 25, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
I want to switch the doors from left to the right side
Hi, The parts are interchangeable (hinges & handles)
You should have some small plastic plugs/caps that are covering the holes already drilled for the change. Once you remove the doors and then remove the plugs, just reinsert the plugs into the old holes and switch hinges and door handles to the opposite spots.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 26, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator door pops open, frigidaire top
Apr 17, 2009 | Frigidaire FRT21H8 Top Freezer...
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
