Question about Radio Communications
How to adjust a Trompeter mini RF Coaxial stripper blade Part# C26T3-D
Posted by christopher nixon on
How do I connect my DMR-EH57 to freeview
Connect a suitable aerial via a coaxial/RF lead to the 'RF in' socket. Connect another coaxial/RF lead from 'RF out' to your TV, and/or SCART or HDMI leads.
Access the 'setup' option within the menus to tune in to Freeview broadcasts.
Oct 03, 2013 | Panasonic DMR-EH57 HDD Recorder Player
My RF-modulator works when I use a short coaxial cable but will not work on longer runs. Why?
RF modulators are intended for short runs. There is too much signal loss for a long run
Dec 17, 2012 | GE Rf-modulator 73452 Connects All Kit
How do i adjust the sideband
Instructions
Connect one end of your coaxial cable to the output port on your SSB Transmitter. Connect the other end of the cable to the coaxial input port on your RF demodulator.
Connect one end of your 1/4 inch audio cable to the audio output port on your RF modulator. Connect the other end of the audio cable to the audio input jack on your amplifier.
Turn on your SSB transmitter, RF modulator and amplifier. Adjust your SSB transmitter modulation by adjusting the knob on your RF
Jul 22, 2012 | Ranger RCI-6900F-25 CB Radio
I have xerox phaser 8400 : when i turn it on it says : service needed fault 37 002 47:115353\r\ncould anyone help for that . thanks
Service Manual says:
37,020.47 = (8400) Strip Solenoid
37,020.47: Strip Solenoid disconnect.
The strip solenoid is not drawing the
expected power.
The Solenoid (relay) may be bad, or the power to it is low.
The Stripper Solenoid positions the stripper blade. The solenoid mounts on the Upper Inner Duplex guide and activates the strip solenoid lever, which in turn rotates the Stripper Carriage
until it hits the transfix ground pins. This action causes the stripper blade to drop onto the deadband of the Drum.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 20, 2011 | Xerox Phaser 8400 Laser Printer
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
The cable plug broke off the back of TV. I took off the back of TV and I'm not sure what to do.
If this model has a/v inputs you could use them and if you're on cable (direct cable not cable box) you could use a vcr to change channels - or you could remove the tuner and resolder the "cable plug" (RF connector) if it didn't crack the tuner circuit board when it came off.
Oct 16, 2009 | Zenith A25A11D 25" TV
Locating a coaxial cable to replace factory supplied cable
Radio shack should have what you need. RG6 is better than RG59 if you have a choice.
Jul 28, 2008 | RCA DRC8335
No RF signal output to the TV through the coaxial cableIs, is that normal?
Yes. This unit only relays the TV signal...the coaxial output can't be used to watch DVDs or play the DVR, all operations are done via the component, composite, or S-Vid outputs. The coaxial simply passes the TV signal out as in from cable TV to DVR and from DVR to TV. If you still do not get an RF signal to pass through th unit, check the cable to make sure the wire is not bent or brocken on either ends.
Jul 14, 2008 | RCA DRC8030N
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Radio Communications Logo
130 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
