Question about Husqvarna Sewing Machines
How can i correct an embroidery mistake in yhe middle of emroidering letters on my husqvarna Diamond desinger
Posted by Carmen Floyd on
Andrew Taylor
    Top Expert:
  • Husqvarna Master
  • 33,424 Answers
5 Related Answers
dupina
Theo du Preez
  • 110 Answers
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Posted on Jan 22, 2008
Anonymous
SOURCE: Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Posted on Jan 10, 2009
Anonymous
SOURCE: can't update my new husqvarna diamond embroidery machine
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
Posted on Feb 27, 2009
Pamsquilt
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
Korede Atunrase
  • 1456 Answers
SOURCE: my Husqvarna diamond top thread
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Posted on Jul 11, 2011
My Husqvarna Viking diamond series embroidery machine does not recognize a formatted disc
perhaps the machines company sells formatted ones . tho the brothers embroidery machine I have will only accept factory originals
Apr 08, 2015 | Husqvarna Sewing Machines
Husqvarna adding sewing fonts
try checking on the huskqvarna website
Apr 18, 2014 | Husqvarna Sewing Machines
Husqvarna viking diamond deluxe embroidery machine main motor overload
I'm not familiar with the Diamond machine but suggest the following. The motor is overheating. Is the sewing machine cord plugged directly into an outlet or are you using extension cords? Voltage drop due to long or light duty cords can cause the motor to run hot.
Can you trun the handwheel freely? If not, there is friction or binding in the machine that needs to be corrected. The blank screen and reboot are simply protection devices like a circuit breaker in your home electrical circuits. Find the source of the problem!
Mar 23, 2013 | Husqvarna Sewing Machines
Replace floppy drive with USB on a Designer 1
Check with a Viking dealer whether Viking offers a conversion kit. My guess is that rather than offer such a kit, Viking would rather sell replacement floppy drives or a newer model of machine.
Dec 21, 2012 | Husqvarna Designer I
Internal timer on Husqvarna Diamond
Sorry, this is information only provided to certified husqvarna viking service technicians. You can see the sewing hours in the user interface by going to the 'tools/set" menu.
Nov 05, 2009 | Husqvarna Designer I
Can't get computer and embroidery machine to connect via USB. Computer doesn't recognize embroidery machine. (Husqvarna Designer Diamond) I also have a new DELL laptop.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Jul 12, 2009 | Husqvarna Sewing Machines
Husqvarna Scandinavia 300 not embroidering desgin correctly.
more than likely its the main pc board but if you had another emb unit you could put that on your machine and if it works fine then its the board inside the emb unit
Apr 16, 2009 | Husqvarna Sewing Machines
Jan 10, 2009 | Husqvarna Viking 1
Can't update my new husqvarna diamond embroidery machine
Nov 24, 2008 | Husqvarna Designer I
Sewing Machines Logo
29 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
