Question about Samsung Televison & Video
Samsung LCD tv mod # LNT3242HX/XAA OTA tuner nothing but noise on all channels.
Posted by Tom Hoo on
    Top Expert:
  • Samsung Master
  • 76,352 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by Mobile or by a desktop to see the search box. Mobile view has no search box.}
Posted on May 17, 2019
3 Related Answers
SOURCE: Samsung LCD tv mod #
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Compliments of the season.
Posted on Dec 30, 2010
KingDWS
Dave King
  • 1606 Answers
SOURCE: My samsung tv model number
This can be one of a couple of things. If you had the power go out it is possible the tv just needs to rescan the incoming signals to find the channels. It's also possible that the video source was changed so that perhaps it is looking for a signal where there is none. ie it should look for cable but is looking at aux input and not seeing anything. If you are seeing a blank blue screen this is probably all that is wrong. You need to go into the menu then setup and select source and then scan the channels. This will be in your owners manual and is easy to do. Usually you only ever do it once when first you get the tv.
If that checks out and you are sur eyou are getting a incoming single then the tv reciever section may have failed. When you have ruled out the souurce then you may need to take it to the repair depot. You should contact smasung and get the closest repair dpot location. You can just go to the webpage and look under support to find and then call and see if they will give an estimate. The repair cost could get close to what a replacment tv would cost.
Posted on Aug 11, 2010
yutianyunren
wisiny.com
  • 848 Answers
SOURCE: SAMSUNG LNT3242HX/XAA REPLACEMENT SCREEN
SAMSUNG LNT3242HX/XAA REPLACEMENT SCREEN? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
IP 45130A Samsung BN44 00127F Power Supply Backlight Inverter
Posted on Feb 02, 2015
NO OTA channels
Not sure this set has a built-in digital tuner. if not, you will need a digital tv converter.
Apr 08, 2014 | Samsung HLP6163WX/XAA
How do I get television channels do I need a antenna without cable?
Yes, you will need an antenna to get live OTA TV. The Haier HL42XR1 has an ATSC (digital OTA) tuner and a NTSC (analog OTA) tuner. Your location and distance to the local transmitters will determine what type of antenna will be best. See antennaweb.org or tvfool.com and enter your address. TVfool.com gives a full list of all stations you may be able to receive depending on your antenna (indoor, outdoor, height, direction). If you share the signal from the antenna with another device, you may need an amplifier to maintain the signal strength. (Warning, when amplifiers fail, the signal can become worse than the unamplified signal. With digital TV, signals are either strong enough for the tuner to understand or a "no signal" message will appear.)
I hope this helps.
May 23, 2013 | Haier HL42XR1 LCD TV
Replacement displays are the most expensive part of the TV and getting a new one will cost more than a replacement TV. You can check on Ebay for a unit that will not power up and you may be able to get a screen cheap enough but it most cases if the screen is broken then the TV is not worth repairing. Sorry
Jul 24, 2012 | Samsung Televison & Video
Is this dvr capable of recording OTA TV?
The SHR-2082 cannot record OTA TV because it does not have a tuner. It is meant to record video from a set of security cameras.
The manual for the SHR-2082 is available from Samsung support here: http://www.samsung.com/us/support/downloads/SHR-2082 .
I wish that I had better news for you.
Jun 17, 2011 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I can watch movies on my samsung LNT3242HX/XAA but I am unable to see or hear anything if i hook it up to cable, i know something needs to be replaced but not sure what? the tuner maybe?? ;p
1. Make sure you have connected the cable to the correct input on the set.
2. Access the User Menu and do a "Scan for DIGITAL" channels.
That should do it...
Jun 13, 2010 | Samsung LN-T4065F Television
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
May 01, 2010 | Sharp Televison & Video
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
You have a really nice TV, you have a built in ASTC tuner(digital).
If you want to recieve OTA(over the air) signals, all ypu will need is an antenna.
Visit this site for some great info on digital TV.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if I can provide further assistance
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 16, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
