Question about Sharp Televison & Video
My tv sharp model lc32le240m has a problem,it turns on and shows image but we can not see it without a flashlight
Posted by Ab Ry on
    Top Expert:
  • Sharp Master
  • 76,352 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://homenol.blogspot.com/
http://electro-medical.blogspot.com/
For some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" of your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}
Posted on May 17, 2019
5 Related Answers
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: my sharp lcd tv model LC 32 SA 1E when turned on
Hi, The T-con problem on your TV. To know more about it please see this video : www.youtube.com/watch?v=2WNzc9zgTzE
Please get it fixed or replace with new one.
Regards, jay
Posted on Feb 22, 2011
Jaime Hernandez
  • 2337 Answers
SOURCE: How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Posted on Sep 13, 2015
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: how do I fix backlight problem on Westinghouse dw 32h1g1 led tv
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Apr 05, 2016
gopakumarg43
  • 76352 Answers
SOURCE: Have a Vizio TV: GV47L FHDTV10A. I turn on the TV, has sound but no picture. Did flashlight test & I CAN see an image when I shine the flashlight on the TV. Videos suggest an inverter slave. Any help?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Nov 07, 2016
larsen84088
lazar vojnic zelic
  • 36 Answers
SOURCE: Samsung lcd tv, no pic but flashlight shows image on screen. Model number un50eh5000fxza
it is a led tv you have problem with led back light strip it is need to replace with a new one (open a display and replace it)
Posted on Mar 11, 2017
Lcd tv screen goes black after a few seconds but sound still plays. The flashlight test will show the image for a short period of time but then it goes away and is completely black.
Hello... It sounds like you have a backlight failure, and the image going away during the flashlight test is due to the TV going into "Protection" mode. A service technician may be able to go into the service menu and clear the lamp error codes and get the TV working, or it may need the backlights replaced. I hope this helps...
Nov 17, 2017 | Sharp Televison & Video
But the trnasistor is no,help the number series transistor tv sharp led model lc32le240m
If you wish to get some details; visit the site linked here. Pull up older posts.
Circuit diagram of many popular sets are given. Hope that it will help you,
Apr 03, 2017 | Sharp Televison & Video
Number transistor for power suplay tv sharp led tipe lc32le240m
That will be found in the service manual or by looking at the transistor.
I have a flat screen flat screen sharp tv model: LC-60E77UN THE SCREEN show only a pin light on the screen
take a bright flashlight and point it on the screen and check if its an image under the black screen and if it does then is you backlight inverter that is damage
Jan 14, 2015 | Sharp Televison & Video
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
My tv sound is working but there is no picture can u please help thanks
With the tv on place a bright flashlight against the screen. Look for moving image around the flashlight. This show an image is getting to the screen but you need a back light to see it.
For an LCD tv you need to replace the back light inverter board.
Since you did not give a make and model I can not help locate the board. You can do it.
Mar 04, 2011 | Televison & Video
Televison & Video Logo
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
