Nextar MA566 MP3 Player Logo
My nextar ma566 mp3 player wont turn on, i just bought new batteries aswell. :(
5 Related Answers
Anonymous
  • Posted on Oct 07, 2008
SOURCE: Nextar ma570 mp3 player wont turn on
I had the same problem happened on my MA570. I finally find that it is easy to be fixed.
The problem is the lost of the Drive software in the MP3 unit for whatever reason. Use the mini CD that comes with your MA570 when you buy the player in the package. Put this mini CD into the PC. PLug your MA570 through the USB with the PC as a removeable device. Clikc the install software on the mini CD and install it into your MP3 player (for example device F:). After you have the new driver installed, you will be able to turn on the MA570 again. Let me know, if this still not work. It works for me.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Feb 05, 2009
SOURCE: Formated nextar ma933 mp3 player
That player is officially toast. There is no recovery software or firmware upgrades for that device - once the key system file is delted, it cannot be recovered.
Anonymous
  • 28 Answers
  • Posted on Feb 17, 2009
SOURCE: nextar mp3 won't turn on/won't let me access files
1. push down the button slider that you see on the side of the mp3 player labeled <mode>. that unlocks it.2. then plug it into the computer, select my computer from the start menu, and click removable disk drive (its usually labeled [E:].) 3. then delete what you need to by right clicking them and selecting delete.
truekleen1
Preacher
  • 46 Answers
  • Posted on May 08, 2009
SOURCE: Nextar MA933A MP3 Player ?
you can download the driver @ nextar.com for Nextar MA933A. However it seems you only need the driver for it if you are using windows 98 or windows 200 prior to SP3. At the link above you can also download the manual, and read the FAQ section.
hope this helps.
Anonymous
  • Posted on May 31, 2009
SOURCE: MP3 Player won't work
I had the same problem too. What worked for me was rolling the battery while it is in the battery compartment and holding the play button at the same time.
How do you turn it on
Hi
Please click on this link to download the manual for your Nextar MA566. Hope this helps...please post back for further assistance.
Daniel
Computer cannot detect mp3 player
If the level of infection by the virus is high, you can try repairing the OS by using the OS cd. You wont loose any installed program if repaired. But the virus will be in dead state after repairing. Then install a good anti virus and do a computer scan. This is the best way to get ride of severely infected virus. The problem you have can be because the virus may have corrupt the mp3 player's exe file
1helpful
Nextar mp3 bought from canadian tire
Us here at Fixya ould like to get some clarification on what the problem and we will help you to fix it. Thank you from all of us at Fixya
WANT TO DELETE
format everything. Use software and manual to help u. or just delete everything manuly useing the software they sent you.
1helpful
2answers
Nextar MA566 MP3 player
Make sure the Hold Switch is to the left. Hold switch to the right will lock the device up. and lot allow any transcations.
1helpful
MA566 is locked
There is a button on the side of the MA566 that you need to slide it back on the left say.
2answers
3answers
Ma566 digital mp3 player
Make sure you have a compatible version of Windows:
the compatible versions (and the user manual) can be found at:
http://www.nextar.com/frontend/mp3_players.asp?MODEL=MA566&subpr=&categ=
Top Nextar Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Vinho Xie
Vinho Xie
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
