Question about Radio Communications
I have Alphasonik AK15PK6-Pair Alphasonik All-in-one 15" 2500W and on it's second use it stops working intermittently. When selecting radio freq it only cycles up through 92.5 and then back to 89.9.
Posted by Ken Hosch on
2 Related Answers
Anonymous
  • 250 Answers
SOURCE: FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 01, 2008
ssikora
steven sikora
  • 6 Answers
SOURCE: radio wont do freq 159.2775
the reason you can not input this frequency, (159.2775 ) is because the synthesizer in that particular radio can not divide down to that exact frequency. Nothing is wrong, just that the electronics will not generate that particular freq. It has to do with the math and what the synthesizer can do.
Posted on Jan 16, 2015
Error message ft-530
is the radio in duplex (offset transmit freq)if keying takes radio out of band it would show err,select simplex ie transmit/recieve same freq
Dec 19, 2013 | Yaesu Radio Communications
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
When the freq reads 27.225 ch reads ch 26 i can talk to folks and everyboby says it sounds fine don't jump freq or anything just ch select off ???
the freq display can be different from the channel selector display. the crystal in the freqcounter maybe going out or just got out of alignment.... check it with a know accurate frequency counter to determine if its on fequency or not. 000 3174269649
Dec 05, 2010 | Galaxy Radios DX-66V Base CB Radio
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
One works the other does not broadcast
The FR50 is a pretty basic radio, where you set the channel select to one of 14 frequencies. The freq number will display on the screen, both radios must be on the same freq to communicate. This being said, if you have known-good batteries and the freq number is the same, your raidos should work together. If not, you have a radio which is defective and will need to be replaced.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/fr50_User_Manual_E.pdf
Best regards.
Dec 30, 2009 | Motorola Talkabout FR50 (14 Channels)...
Band selection an freq. doesnt align galaxy 33hml
sounds to me someone was tampering with it ,your best bet is to get a frequency counter and realine the radio .start from 27.185 centre band you can do this by tuning the ossolator be very careful not to damage this should realine the radio for you goodluck
Oct 16, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
Columbia FRS-S14 two way radios
Are you just looking for a way to program them to the same freqs? But if they are FRS family radio then they should have the same channels in them.
Oct 18, 2008 | Radio Communications
Hello snorker,
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Radio Communications Logo
116 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
