Question about Makita 12? Metal Cutting Saw # LC1230
I purchased the Makita LC1230 Cold Cut Saw today, when I took it out of the box I noticed the box bottom was covered in an Oily Substance The leak appeared to be coming from the main body of the saw.
I immediately took it back to the shop they were going to swap it with another LC1230, that was sitting on display, but that also had a pool of oil which had leaked from the main body onto the base plate. I wouldn't think this normal but hey I could be wrong, any advice? Thanks in advance.
Posted by steve pendleton on
5 Related Answers
George Obray
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
Anonymous
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
emissionwiz
Marvin
  • 85239 Answers
SOURCE: leak onto floorboard
Here is what all dealers do to find water leaks, we spray a fine mist of water on the car near where the water might be comming in with a spray nozzle, someone gets inside the car and look for the leak, there is no other way, and I have been doing this 30 years.
Posted on Dec 03, 2008
Anonymous
  • 3 Answers
SOURCE: I have a coolant leak.2001 alero 4cy 2.4
Look around the sides of the motor. Aleros are famous for faulty pan gaskets. Ours has been in the shop twice for this. If the mechanic doesn't get it put in just right it will continue to leak.
Posted on Jan 26, 2009
Anonymous
  • 580 Answers
SOURCE: i have 2000 bmw x5 and just noticed that it is
Check the oil pan drain plug make sure it is secure and has not been cross threaded the last time your oil was changed
Posted on Jul 11, 2009
Battery operated candle won't work. I took out the batteries and I noticed an oily substance. Still doesn't work with new batteries. Why?
Check your contacts where the batteries go in. The substance is likely corrosion from old batteries you left in too long. The contacts could be rotted off or not working any more.
Noticed an oily substance on the left front came out but cannot see where coming from -checked the oil and that is fine
More than likely it is leaking a few drops of engine oil either trough the valve cover gasket or from one of the valve cover bolts. more like the valve cover. Could be just loose. Check the bolts for torque.
Steering
Need to replace a worn out steering rack
& flush the Power Steering System
Have to install a Return Line Filter after
the cooler or you have no warranty on new rack
If you change power steering & transmission fluids on all vehicles every 3 years, you avoid expensive repairs,but yours
is 18,19 years old, so you got an ongoing restoration project,
not a daily driver
Freezer and frig not as cold
It sounds like the heater that automatically defrosts the unit may have failed. Before calling service I recommend checking the following: all door seals, make sure they are closed and sealing properly, also the condenser coil either on the back or bottom of the machine should be vacuumed out regularly to get rid of dust buildup. If that's all good it may be the defrost heater and if you're handy you can look up on youtube how to replace it or call a professional.
1helpful
Makita gas saw has too much gas entering the carburetor
The fuel inlet needle in the carb is leaking, replace the needle with a new one, the needle is rubber tipped and will wear espesially on a power cutter due to dust in the fuel tank, when replacing the diaphram make sure the gasket goes to the carb first followed by the diaphram and cover, the gasket is used as a spacer, so if the diaphram goes on first it will be too close to the metering lever and will leak.
Jan 11, 2012 • Makita Saws
1helpful
Brand new Makita MAC2400 is leaking oil.
Send it back Right now do not keep iT NO IT SHOULD NOT BE LEAKING LIKE THAT Paul
1helpful
PAC L90 leaking oily substance
it leaked all the freon and oil out .
it needs to be vacuumed and oil replenished.
filled with freon.
should only cost you bout 50.give or take
as they use very little freon.
a shrader valve port has to be added to introduce the freon. takes just a few seconds.
30helpful
2answers
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Makita  12? Metal Cutting Saw # LC1230 Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
