Question about Car Audio & Video
Can i run my kicker1000.1zx to thisntx7912 sub
Posted by rusty on
2 dvcoil 4ohm.subs, need 2 ohm load total for monoblok.amp. how do I wire.it
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
Oct 15, 2015 | Ohm Car Audio & Video
Is the sub out strictly for a powered sub or is there a way to hook up speaker wired subs to that
The sub out connection is for powered subs. To use a sub that runs off of the amp power, you'll will have to run it through the main speakers. Usually, on this type of sub, there are connectors that allow the frequencies above the sub range to bypass it and go on to the main speakers (the sub filters the lows and passes the highs on to the speakers). If your sub does not have this, then you'll have to get a separate amp for your sub to run off of the sub-out.
Dec 01, 2010 | Sony STRDH710
I have two 12" Alpine Type-R subs running on a
9check connections inside sub enclosure(assuming they are in one)mine loosen up after running them hard for months on end.they act the same way yours are.
Jan 24, 2018 | Alpine Type-R SWR-1222D Car Subwoofer
Have a 2000 gmc sierra ext cab pickup and two type R swr-1042d subs and would like to know the best enclosure for the subs to get maximum performance and the best ways to hook up a one channel mono alpine...
it depends on the amp what can it handle. will it do 2 4 or 8 ohm is it 1 ohm stable are the subs dual 2 ohms or dual 4 ohms. 1042s are dual 4 ohm subs so if you wire them both in paralel it will drop both subs into a 2 ohm load for each sub that is pos of one coil to pos of sec coil then pos to pos on amp and same with neg to neg to neg on amp. now if your amp is 1 ohm stable i would do both subs the same way you will get the most power out of the amp. but itll run a littl hot if you dont have adaquate power running to the amp. now i wanna think your alpine amp maybe only 4 ohm stable. i would run both subs like i had said pos to pos then neg to neg now both subs will be a 2 ohm load so what you do to bring it back up to 4 is you run the 2 bridged subs into a series which is pos from one sub to neg of the other sub the remaining pos and neg will run to the amps pos and neg. which will make it into a 4 ohm load. now the last scenereo is your amp is 4 ohm or 2 ohm stable. this is how to wire it to 2 ohms and not 1. take one sub go pos to neg then pos to pos on amp and neg to neg on amp this will make an 8 ohm load with one sub take other sub and do the same neg to pos on sub then pos to pos on amp and neg to neg on amp this will tell amp to run a 2 ohm load. 2 ohms is a good run for these subs if the amp can handle a 2 ohm load. now if you would have given the amp model number i could have looked it up to just give you what you needed but with this short info i gave all possibilities.
Apr 20, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
Im trying to run two kenwood 6/9,s and a mtx sledge hammer 12'' sub of a mtx 6004 amp.where do i put my rca,s front or rear / and if this is poss how do i bridge the sub ????? im lost
Im kind of confused with what exactly your asking. Are you trying to run 3 subs off of an amp? If so, the RCA's should go to the front of the amp, and if your plugging 3 subs in to it, you need to have a 3+ channel amp. There is a way to hook it up differently though. I have 4 12" Hifonics subs running off a 2400 watt Nitro-BMW-486 amp. I just have two subs running to each of the two channels.
Sep 26, 2009 | Car Audio & Video
How do you wire sub speakers to change omes
if you have a 4ohm sub you can series it with another to make a 2ohm load. this is done by + from amp to + on one sub then take the - of that same sub and run it to the+ of the other sub then you only need to run a wire from - of that sub to the - on the amp. NOTE IF YOUR AMP IS BRIGED THIS IS A 1 OHM LOAD!! IF THE TOO SUBS ARE ON ONE CHANNEL THIS IS A Two OHM LOAD IF YOU ARE RUNNING 8 OHM SUBS THEN YOUR AT 4OHM PER CHANNEL AND 2 OHM BRIGED
Jun 13, 2009 | Kenwood KSC-WA82RC Car Subwoofer
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Sub Wiring
if you wire the subs in parallel you would achieve 2 ohms which would theritically double your rms, sadly this isn't the case what with wire resistance and such you might get around 270 rms still not that bad. to wire in parellel you run a positive off the amp to the positive on one sub then run a wire from the first subs negative to the second subs positive the run from the second subs negative to the amps negative and bam 2 ohms but be warned this will put more stress on your amp and cause it to heat up faster. peace bro and best of luck
Dec 14, 2007 | Phoenix Gold XS6600 Car Audio Amplifier
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
