Question about Dewalt Tools & Hardware - Others
DeWalt 5" random-orbit sander start to make high frequency noise after few hours of work
Posted by Mario Nadeau on
  • 3 more comments
  • Steve Pack
    Steve Pack May 14, 2019
    Hi Mario Nadeau, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Check bearings
  • Mario Nadeau
    Mario Nadeau May 15, 2019
    The model is DWE6423K. I just bought it few days ago. After sanding a painted wall for hours (taking a break after around every 30 minutes)
  • Steve Pack
    Steve Pack May 15, 2019
    Return it for one that works. I like Home depot because you a 90 day return policy.
  • Mario Nadeau
    Thanks, I will do that.
  • Mario Nadeau
    I did return it to Home depot. They told me that it was not made for sanding painted wall but only wood and that they shouldn't have sold it to me for that kind of job. What probably happened is that the paint dust got hard inside and cracked the ball bearing. They gave me a store credit for the full amount.
5 Related Answers
stug_57u
Stuart
  • 99 Answers
SOURCE: orbital sander
You should really take it back to place of purchase and get it replaced/fixed under waranty. If you try anything other than checking the fuse you will invalidate the warranty. Most manufacturers allow retailers to replace faulty tools within seven days of purchase. Be sure to take your receipt with you as a copy will be needed for the shops warranty claim.
Posted on Nov 01, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Posted on Jan 12, 2009
comax
Corey McConnell
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
Anonymous
  • 384 Answers
SOURCE: orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Posted on Jun 12, 2009
Anonymous
  • 32 Answers
SOURCE: Makita 5" Random Orbit Sander
The armature windings have an overlay problem in the wiring causing this and there is no soluation except to replace the armature which is not cost efective unless you are still under Warrantee and get a free replacement, it will burn up at some point. If you bought it within the last month take it back and get a new one, over one month, pack it back up in the original box and send it to address in the owners manual for repair or replacement service addresses.
Posted on Jul 18, 2009
What is happening to my Dewalt DW421 spinning fast, but no random orbiting motion.
Probably need to replace bearing 6202. I took mine apart, dissambled the retainer and used PB Blaster on the bearing. It seems to be a short term fix. At least it's not operating at hyper speed anymore. Long term, I probably need to replace the bearing and maybe a new lower retainer if I can't press the bearing out.
May 25, 2013 | Dewalt DW421 5'' orbital sander
Can I use sanding disks with no holes on a D26453K orbit sander?
yes as long as it is the same type of disc, e.g. hook and loop or psa.
Aug 28, 2011 | Dewalt Heavy - Duty 5" Vs Random Orbit...
Dewalt d26451 type 1 random orbital sander. why does this sander jump around on the material and feel like it's fighting me all the time instead of sanding smooth and easy?
I have the same problem with a Porter Cable orbital sander I recently purchased. Whats happening is the sander is catching the edge of the board you're trying to sand and jerking back and forth as the sander base spins. It seems that if the board your're sanding is at least as wide as the sander base, the problem goes away, which does little good because there will be many times I we'll need to sand wood that is less in size. But you may try using a lesser grit sandpaper and see if that alleviates the problem somewhat.
Aug 10, 2010 | Dewalt Heavy - Duty 5" Random Orbit Sander...
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
Orbital sander doesnt orbit!
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Intermintly will not come on
Take the brushes out, inspect them, and blow out the whole tool with compressed air.
Mar 17, 2009 | Dewalt D26453 3 Amp 5 Inch Variable Speed...
Jan 11, 2009 | Makita Tools & Hardware - Others
Tools & Hardware - Others Logo
189 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
