Question about Hayward Pool & Spa
Can the Hayward Critter be left submerged when not in use? Ran out of daylight before finishing opening cleaning & will resume tomorrow. Turned off filter/suction.
Yes
Posted by Lou-Ann Keppler on
5 Related Answers
jbrown98
Jonathan Joshua
SOURCE: Suction problems
One thing Dyson did recommend is to take an air compressor (or hair dryer) to the thingy in the collection reservoir. This seemed to help a little...
Posted on Apr 11, 2009
amanforallre
  • 77 Answers
SOURCE: I have a hayward pool pump. I ran the back wash
It sounds like the start switch contacts are not making good contact or there also may be a weak capacitor. These possible solutions do require a basic knowledge of motors to remedy. Start contacts can be cleaned and adjusted until proper replacement can be done.
Posted on Aug 18, 2009
Testimonial: "Thanks for the help. It worked."
poolyoda
  • 128 Answers
SOURCE: Hayward super pump II low pressure 10 psi suction and return low
You have a clogged impeller
Posted on Aug 23, 2009
Testimonial: "thanks for the response. That is exactly what it was. Got frustrated and just started taking things apart, but you are right on the money! tks again."
Dale Cobb
  • 366 Answers
SOURCE: Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Posted on Sep 16, 2009
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: no suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
Posted on May 24, 2010
Dishwasher is not cleaning and soap is not dissolving.
The first and most likely issue is blocked spray arms or a blocked filter. Unclip the spray arms from the machine and ensure every hole is clear of debris. to clear the arms out, gently poke them clear, then submerge the arm in water, lift it out and, tip the arm to the left so water and debris run out of the hole, then to the right. Do this LOTS of times, resubmerging to fil with water then tipping left and right and shaking slightly to get water and debris to run out of the centre hole. Continue this until, when you lift the arm out of the water and tip ot vertical, you can see water runs unobstructed from the lowest hole in the arm. If there us anything there, go back to submerging, then tipping left and right again until the arm is completely clear. Next, take the filters out of the bottom of the machine and clean them until they are spotless (If you're scared to lick them, they're not clean enough, so keep cleaning them until they are!). Replace filters and arms and try again. ALSO check that the heater is working in the machine. Simply open the door mid cycle (Carefully!) The machine will stop washing and you can check if the water is hot. Close the door back up again. Some machines will wait 20 seconds or so then restart automatically, some (Particularly some Bosch models) will need you to press the start button to get them to resume the wash.
Sep 25, 2015 | Dishwashers
Why don't I have suction from my Hayward Dual Submerged Suction Outlet?
First... is the pump running? If not, find out why. Is the circuit breaker tripped? Does it have a switch? Is the switch turned off?
Jul 31, 2014 | Hayward Pool & Spa
I accidentally inverted the ground and 12v connection coming from the radio. i realized this a few minutes after trying to figure out why amp wasnt powering up. will it still work once i re-establish...
This should still work if not then check fuses first. If no big spark happened when you turned it all on then you are definitely good to go. The only way to know for sure is try it out
Mar 24, 2010 | Car Audio & Video
Aug 16, 2009 | Hayward Pool Products Economy 1 Hp Above...
My Aqua Critter seems to get clogged up pretty quickly. We just opened a pool that had been closed for a year. There are a lot of leaves in it. Is that why it cloggs so quickly?
It most certainly is.
The simplest solution, is to sort of half the work for it, by collecting as much leaf litter, as you can with a net, before sending in the critter.
Also, a cover, will drastically minimize the amount of litter entering the water.
Have fun fishing:)
Jul 26, 2009 | Hayward Aquabug Above Ground Pool Cleaner...
Aqua critter
Remove the center inlet port and check for some sort of blockage in the intake jamming the drive paddle.
Jun 14, 2009 | Hayward Aquabug Above Ground Pool Cleaner...
Can not open dishwasher door
is the child safety lock to the left or right? (its located in a recessed space where the main handle is) if its to the left then its locked and will need to use something like a matchstick inserted in the small hole next to the switch to deactivate it.
May 08, 2009 | Bosch Evolution 300 SHE33M05UC Stainless...
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Pool & Spa Logo
99 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
