How do you tune a techwood 400 stereo reciever
Posted by Christy Dann-Brown on
1 Related Answer
Anonymous
SOURCE: Techwood 400 watt Stereo Receiver PLR85
the protect light keep comming on
Posted on Aug 21, 2010
Cannot get techwood tuned in to sky through rf do not have a manual
Sorry to say modern TVs do not have an analogue tuning system, which you need for a SKY box RF output. Your local TV dealer may have an RF receiver that you can connect to a SCART or RCA socket on your TV
Feb 06, 2018 | Televison & Video
How can I listen to audio from Techwood TV/DVD player through home stereo? I have connected a red&white stereo lead & selected aux on my stereo, but sound still just comes out from the TV. Any help is
Make sure that you are using the Audio Out ports (not one of the audio in). Next go into the menu. Select the Audio setup option and see if there is a line for enabling the external speakers. (Often this corresponds to turning off the internal speakers but not always.)
I hope this helps. I'm not familiar with the specs of Techwood TV models. Some TVs only have an headphone/earphone (3.5 mm) jack as their audio out. In that case, you'll need an adapter to convert the RCA audio to the headphone jack.
Dec 09, 2011 | Televison & Video
I have a Techwood reciever. I need to replace the motor for the fan. Please tell me where I can order this part! Thanks a bunch! Diana
I believe that Techwood is no longer in business. You could try electronics site such as mcm electronics or encompass electronics for a fan.
Feb 09, 2011 | Audio Players & Recorders
Ford radio wont tune in
remove the stereo and make sure areal is plugged in to the back of the set, if this is all ok then remove interior light and make sure the mast connection is tight and nor corroded.
if these are ok then it will be the reciever in the stereo that will be at fault
let me know if this helps mate
cheers
mike
Jan 19, 2011 | 2001 Ford Focus
Can I connect a Computer to a Techwood DDR 94 AV Digital Surround Receiver so that I can listen to radio stations online?
Yes. You can. First, you need a cable that has a stereo pin called stereo jack (the type that has on ear phones/head phones) on one end and component cable terminals (the type that comes with video/ audio left and right) on the other end. To further explain, these terminals come in yellow red and white colors. You only need the red and white ones. This is available at electronic stores. Otherwise a person who service electronic equipments can easily make one. Basically, this cable will have a stereo jack (small one) on one end and split into 2 cables with the red and white terminals. Once you have this cable, connect the stereo jack to the ear phone socket of your computer and connect the other end to the audio input of your Techwood receiver. You can select anyone (CD, DVD or TV). These inputs are right above the speaker wire connections. Be careful to connect to the socket that say "in" . Now, let us assume you have connected to the CD, select your source as CD on your techwood receiver. Play music on your computer and you should be able to hear the output through your Techwood receiver. Good luck
Apr 05, 2010 | Computers & Internet
Techwood stereo system
i have a techwood 5 disc changer and when i plug up changer the lights go out on radio
Jun 30, 2008 | Audio Players & Recorders
Techwood DDR94A stereo
i found the manual to the Techwood DDR94A at diplodocs.com
Apr 08, 2008 | Audio Players & Recorders
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
Metrik headrest DVD player
try manually tuning your stereo up and down one or two places either side of the suggested frequency to fine tune it.
or if the frequency modulator has several presets, select a different frequency & retune the recieving stereo.
Dec 18, 2007 | Lanzar SVDVDIN70 Car DVD Player
21 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
