Question about Food Mixers
Need a flat paddle for my Cooks stand mixer - Food Mixers
Posted by Bob Moravecek on
Andrew Taylor
    Top Expert:
  • Food Mixers Master
  • 32,985 Answers
Google
make model replacement parts
They are all available online.
Posted on Jun 19, 2019
5 Related Answers
Hal Hallman
  • 770 Answers
SOURCE: no sticker/model number on the bottom of my stand
Since you have not given a make...I'll take a stab in the dark and bet you have a kitchen aid...simply because you mentioned the dough hook. Kitchen aid has 14 models of stand mixers. You can match yours up and look at available accessories at www.kitchenaid.com
Posted on Sep 01, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: I have a Cooks stand mixer and cannot get the
You didn't oil yhe beater stems. Pour some wesson oil doen the stem sockets and sorta wiggle the beaters and work the release while doing so. First unplug the unit.Pour a tad bit around the release also.
Posted on Oct 28, 2009
Anonymous
SOURCE: bowl is being scraped by paddle on stand
There is a screw that turns about 180 degrees on the stand behind the bowl that fine-tunes the height of the paddle.
Posted on Dec 16, 2009
gravesyale
SOURCE: Need owners manual for Cooks 12 speed 5-qt. 700W
Try JC Pennys product service department 1-800-933-7115 thats the only number given in the manual.Just bought one today and I been on line trying to find out where to buy accessories like meat grinder so far no luck may have to take it back...
Posted on Jan 06, 2011
shazwilki
  • 5 Answers
SOURCE: I have ordered 3 cooks professional stand mixers for myself, my daughter and daughter in law and none of us am remove the mixing bowl - can you help?
On the right hand side of the unit there is a lever..lift the lever upwards and tilt back the head.
Then hold the bowl with both hands and twist to the left to remove the bowl.
Hope this helps you.
Posted on Dec 17, 2016
Owner manual for Cooks stand mixer model #SM248
this page says it has it, but I am a bit concerned that it is a zip file
Download cooks stand mixer owners manual ' Diigo Groups
https://groups.diigo.com/.../download-cooks-stand-mixer-owners-manual-6694925stand mixer Model SM248, 700 watt, 12 speed, 5 qt http://retrorenovation.com/wp-content/gallery/1960-drexel-catalog/drexel-profile-18.JPG Documentation Location Service: Reference Information Report for KitchenAid Classic Stand Mixer KSM5 Service Manual cooks stand mixer owners manual. Service manual for the ...
Cooks stand mixer model SM248 manual Google Search
Feb 14, 2018 | Food Mixers
Where is the Height Adjustment Screw on the KitchenAid K45SS Classic Stand Mixer? [email protected]
It is in the front middle of the hinge area, visible with head raised. Clockwise to lower and anti clockwise to raise. Head height is set with flat paddle to just clear the bottom of the bowl when head is locked down.
May 25, 2014 | KitchenAid K45SS Classic Stand Mixer
Old Kitchen Aid classic (25+), new KA-TH beater bar and suddenly the bowl won't stay mounted. Is it the beater bar, the mounting or something else?
You may need to adjust the head height if the new flat paddle is a bit bigger than the original. When you have the head lifted up with beater out of the bowl you will see a single slotted screw where the head hinges on the pedestal. Anti clockwise to lift the head up, clockwise to drop the head lower. Paddle should just clear the bowl with head down & motor running.
Oct 25, 2013 | KitchenAid K45SS Classic Stand Mixer
Cooks model sm 248 mixing parts and break down on parts along with owners manual or opereting manual
i have searched the web and cannot find a instructions Manual for the Cooks mixer Model sm248... any help?
Nov 13, 2011 | Cook's Essentials 700 Watts CESM100 Pro...
I have a ksm150psbu my daughter gave, almost new. she didn't like it as the beater left too much product in the bottom of the bowl and it didn't mix together. Is there some adjustment that can be...
The head height adjustment screw is visible from the front when the head is raised. Looking from the front it is right at the back where the machine head hinges on thew pedestal. Clockwise to lower and anti clockwise to raise the head. You want it as low as possible without the flat paddle tinging on the bowl when the motor is running. Kitchen aid also make a paddle with rubber edges, called a scraper paddle. That one wipes against the bowl during operation.
Nov 12, 2017 | KitchenAid KSM150PS Artisan Series Stand...
I need a paddle and Whip attachment for the D300. What are the part numbers?
275450 "B" Flat Beater Aluminum
275451 "B" Flat Beater Stainless
275899 "D" Wire whip Stainless
Aug 03, 2011 | Hobart D300 Stand Mixer
Bowl is being scraped by paddle on stand mixer. how do i adjust it?
Sep 24, 2009 | KitchenAid KP2671 Professional 6 Series...
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
Food Mixers Logo
137 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
