Music Logo
netsanet ejo Posted on May 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want europower pmp300 power suply servic manual
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on May 14, 2019
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7548731
Points
193449
You will want to try manufacturer or online search
Behringer Europower PMP500 using 1/4 inch cables for speakers?
Question edited for maker.
Question moved from Musical Instruments to correct category.
Running a 1/4" cable has no bearing unless you are trying to run a hundred yards of cable. Check your plugs wiring and connections to the unit. Here is the manual.
https://www.manualslib.com/manual/573726/Behringer-Europower-Pmp500.html?page=4#manual
Service manual
Owner's manual has phone number for company to request a service manual.
http://www.fullcompass.com/common/files/18689-PMP2000UserManual.pdf
2answers
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
7helpful
2answers
I need the diagram of behringer europower pmh1000
Here:
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
1helpful
2answers
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
Power suply
If the power supply fried, it is likely one of the power amp channels, usually the rearmost one has fried. There is a weak insulation thing between layers of the multi-layer circuit board that shorts.
DO NOT replace a fuse in a failed unit till problem is fixed as you will LIKELY do more damage!!!!
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
