Question about Kenmore Cooktops
Our kenmore elite cooktop suddenly tripped the main breaker. I reset the breaker and error code E showed up on all element controls and none of the controls work. The error code E is not blinking.
The trouble shooting guide says turning the power off and on will reset the cooktop main controls but this is not working. What do you suggest I do?
Posted by Barry Imhoff on
1 Related Answer
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: electrolux cooktop was in use and suddenly tripped breaker. When reset, showed error code across control panel. tried sabbath mode unlock, but no success. suggestion?
    What was the error code?
    Posted on Jul 30, 2012
    NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
    Problem: Error codes 26 or 42 after turning on too many heating elements.
    Potential issue: Damaged main electronic board
    Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
    Root cause: Dying/blown electrolytic capacitor on the main electronics board.
    Solution:
    1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
    2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
    3) Remove all screws around the metal housing using a torx screwdriver
    4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
    5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
    6) Next open the black plastic cover by removing four Torx screws.
    7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
    8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
    9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
    10) Reassemble and done.
    May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
    All 4 elements suddenly won't heat--worked fine this am. Circuit breaker was tripped. Reset, now lights on knobs come on, but still no heating.
    Likely a short in the junction box. Turn off the breaker and open the junction box for inspection. Problem is likely at the cooktop end of the feed from the breaker.
    Check voltage at the junction. Should one side of the corcuit be dead, turn off power and call an electrician as the wiring probably has had a short due to staple or nail penetration and would be a fir hazard. Call an electrician if this is the case.
    Jan 12, 2010 | Jenn-Air JED8430 Electric Cooktop
    Kenmore Elite Induction Cooktop Error Code 41
    I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
    I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
    Anyone else experienced this failure??
    Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
    Tripping breaker
    Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
    Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
    Error codes 10 12 16 on kenmore induction cooktop
    We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
    Link for manual on web site appliancejunk. com is below
    http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
    Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
    Igniters will not work
    did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
    Dec 24, 2007 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
    Cooktops Logo
    162 people viewed this question
    Top Kenmore Cooktops Experts
    Michael Thomas
    Michael Thomas
    Lawrence Oravetz
    Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
