Question about GE Refrigerators
My ge monogram refrigerator model zfsb23drg only dispenses crushed ice when I press the ice cube button. The water dispenses properly and crushed ice dispenses properly but when I press the ice cube button all I get is crushed ice. All other functions work correctly
Posted by Laurence Popiel on
David Spradling
    Top Expert:
  • GE Master
  • 11,272 Answers
Bad switch if voltage ok bad control board
Posted on Apr 16, 2020
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Maytag refrigerator, Model MSD2454GR
Your best bet is to shut the unit down for a while and let it defrost. You've probably got your box set too cold. 0-5 degrees on freezer...38-42 on fridge side. If your unit is not digital, use a regular outdoor thermometer, close the door for half an hour and then open to read it. Adjust accordingly. If too cold...you're using too much energy, too.
Posted on Jan 03, 2008
Anonymous
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
Anonymous
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Anonymous
  • 39 Answers
SOURCE: only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Posted on Jul 15, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
GE Monogram is only dispensing crushed ice even though the cube option is highlighted on the door
The ice been has become dislodged. Pull it OUT then reinsert it until it locks in place.
Jan 01, 2010 | GE Refrigerators
Our GE Monogram Icemaker will only dispense crushed ice
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice,...
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Jul 22, 2009 | Refrigerators
Only crushed ice comes out of dispenser
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Dec 31, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Arsim Shabani
Level 1 Expert
