Question about Dewalt Tools & Hardware - Others
I need help reassembling a Dewalt DW433 sander.
I replaced one of the tensioning rollers and noticed two cylindrical rollers on the table and do not know where they go back. The diagram of this sander shows this as tracking roller item 29 but no arrows showing where they go.
Posted by Bill Adams on
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Posted on Apr 01, 2009
Anonymous
  • 1985 Answers
SOURCE: i NEED A DIAGRAM SHOWING HOW TO REMOVE THE TIMING
it be in your best interest if you would buy a Haynes book on your car from AutoZone for about $20.00,
It is what I use at the shop,it gives alot of info even wiring diagrams,to engine rebuilding.
Posted on Jan 19, 2010
seanpwright
Sean Wright
  • 2030 Answers
SOURCE: Dewalt DW433 belt sander stop working, why?
Check the brushes for the motor they may have gone bad or broken, I have seen this happen before on dewalt tools.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Apr 02, 2010
radar001
Bob Korsu
  • 1051 Answers
SOURCE: I just used my DeWalt
You can probably get an owners manual at www.retrevo.com It's a free site but requires registration (also free).
Posted on Oct 31, 2010
daryl441918
Daryl Nash
  • 1280 Answers
SOURCE: Our Canon PC950 has recently
Yes the smudging is a sign that you are running out of toner. Check with someone like Office Depot and be sure they have your toner cartridge in stock. Instructions on how to remove your cartidge and install the new one should come with it.
Posted on Feb 28, 2011
I just need to know how to remove and replace the drive pulley on the DeWalt 432 belt sander.
You need a Screwdriver (Phillips) and a pair of Pliers... Get the Pulley FIRST, Take the screws out and split the case, you will see the Pulley. Replace the Pulley and reassemble
Apr 08, 2013 | Tools & Hardware - Others
I bought a DeWalt belt sander model DW433, yet no manual.Lowes told me I can download it online. The problem it only comes in spanish, so where can I get an english one? This is America isn't it?
I found the manual in English (pages 1-2), French (pages 2-4) and Spanish (pages 5-6) as a PDF here: http://servicenet.dewalt.com/Products/Detail/DW433# . See under Downloads on the right hand side of the page. Multi-lingual manuals are the current normal due to international manufacturing and sales; it saves in the production/packing costs.
There are other models that start DW433. to get their manuals start here: http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW433&searchType=0 . Start at http://servicenet.dewalt.com/ for other Dewalt tool manuals.
I hope this helps.
Mar 21, 2011 | Tools & Hardware - Others
Dewalt DW433 belt sander stop working, why? While sanding shutters, my sander just stopped. Any fixes?
Apr 02, 2010 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
BELT SANDER ADJUSTMENT
Try removing the adjustment screws and applying some Teflon thread sealant. That should prevent the screws from turning on their own. Another thing you can do it check the pulleys with calipers and make sure it is still cylindrical. I have seen ones that become worn on one side. Finally, roughly check the belt tension on both sides and make sure they are approximately the same tension.
Good Luck!
Ben Steigerwald
Jan 11, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
171 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
