Televison & Video Logo
R
Roy sargeant Posted on May 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jvc tv just turned off can not see blue light can not switch on manually or by remote completely looks dead model number. Lt 39c740a. Please help
Franco Dosil
Level 3:
Top Expert:
  • JVC Master 10,542 Answers
  • Posted on May 12, 2019
Franco Dosil
JVC Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377878
Points
178965
Hello Roy, for what you describe, your JVC TV, has power problems
You can try plugging it into another power outlet, if you have power cord, interlook type, you can change it
If with all these tests, you have no result, the problem is inside the television, probably in the power supply
If you have technical knowledge, I suggest you remove the back cover and locate the power supply and check if the fuse is burned, if so, replace it with an equal one, no more small, or larger current capacity, to avoid faults worse
If the fuse is bad, replace it and burn again, this would definitely say that the problem is in the power supply
In this case, I suggest you approach a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Roy, por lo que describes, tu televisor JVC, tiene problemas de alimentaci?n de energ?a
Puedes probar conectarlo en otro toma corriente, si tiene cable de corriente, tipo interlook, puedes cambiarlo
Si con todas estas pruebas, no tienes resultado, el problema esta dentro del televisor, seguramente en la fuente de alimentaci?n
Si tienes conocimientos t?cnicos, te sugiero que le saques la tapa posterior y ubiques la fuente de alimentaci?n y revises si el fusible esta quemado, si es as?, reemplazalo por uno igual, ni mas chico, ni mas grande en capacidad de corriente, para evitar fallas peores
Si esta mal el fusible, lo reemplazas y se vuelve a quemar, esto dir?a definitivamente que el problema esta en la fuente de alimentaci?n
En este caso, te sugiero que te acerques a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.teamknowhow.com/content/dam/pdf/JVC%2039'%20LED%20Smart%20HD%20TV%20LT-39C740%20Manual.pdf
5 Related Answers
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Anonymous
  • 105 Answers
  • Posted on Apr 29, 2009
SOURCE: JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
vinhson65
  • 257 Answers
  • Posted on Aug 13, 2009
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Anonymous
  • Posted on Jan 03, 2011
SOURCE: My JVC LT-47X579 is not "turning on" since we
hmm i had the same problem the saturday before on my lt-42x579but i didnt have anything hooked up to it blue light came on then flashed ..no pic this happend one week after it was pd off from a rental store we should investigate
Anonymous
  • Posted on Jun 19, 2012
SOURCE: JVC LT-42X579 blinking blue light
wow thanks you thanks you God bless you who figured it out worked fabulously thanks again
JVC 32"(81cm) Full HD LED TV (LT-32N310A). Does anyone know the Remote Model Number?
Question edited for clarity.
Or buy using the television model, not by remote model. Walmart carry them. Check model number carefully when looking at Amazon and eBay listings.
https://www.google.com/search?q=JVC+LT-32N310A+replacement+remote
Two specialist websites in this Fixya Tip I wrote about Remotes.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Keep asking for best picture settings for jvc television model lt-39c740A but getting no reply no very impressed
There is no such thing as a best setting. The "best" setting depends on many things, such as the room brightness, the direction of the light (if any), and your own eyes.
No one can tell you the best settings without knowing the details. Are you watching in a dark room or a bright room? Is any light coming through the windows? In which direction? And most important of all, what looks best to YOU?
TV won't turn on (completely)
moved you to television forum random model not told.
lost the remote
first TV ever?
and batteries died in remote, I am on set 24 batteries in 12 years.
see how batteries sux
all TVs have reset,
ever read the manual first after all no 2 TVs are the same.
so we read the manual
screen is dead but are menus dead.
the rear of all TV s made a label and we read it and the model is there. like my wild guessed one top of this page;.
post you real model or get no answers correct. ever.
if TV is older than 2010 CCFL lamps inside are dead. use flashlight to see that is ture or not.
on my TV the red LED goes out turned on, so you do no have to start at it forever, a huge pain that but must turn out or PSU is dead in TV or the silly batteries in the remote are dead, or weak
read that word 2 times for effect, WEAk.
1helpful
No power on TV - JVC LT-47X788 47 in. HDTV LCD
Power supply board is dead.U have a LED light indicator on LCD panel flashing?The tv is completely dead,no LED light at all?Tries Website like Shopjimmy.com.Ebay.com to buy a refurbish power supply for the replacement.
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
104helpful
4answers
44helpful
3answers
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
2)wait 10 sec
4)wait 30 sec
25helpful
Blue light
2)wait 10 sec
4)wait 30 sec
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
