Question about Video Cameras
Eating tapes Camcorder eating tapes
Posted by yolanda on
john h
    Top Expert:
  • Video Cameras Master
  • 23,424 Answers
Probably needs a cleaning gears usually get gummed up or the belt broke
Posted on May 12, 2019
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,542 Answers
Clean the rollers and recording head with a foam q tip and iso alcohol. hopefully that will work for you
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: Optura Pi is eating tapes
hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
Posted on Apr 30, 2006
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Posted on Feb 12, 2008
JULIANFIX
ALBERT GARCIA
  • 975 Answers
SOURCE: eating my vcr tapes
ok , lets start with MOISTURE where VCR located ,what happen is that moisture can cause the tape to catch on the polished surface of the drum head , some instances will play,but the tape stops stretching it and damage occurs. SECOND check for a defective idler tire that prevent the take up reel from spinning. also check for any drive belts ( look like black rubber bands ) that might be stretched with time ,replace with new ones .hope this info helps
Posted on Apr 18, 2008
Anonymous
SOURCE: tape eating
my camcorder eats the tape and i have alot of tapes that i recorded on it and i can't see them any where else.and no body fix camcorders in my area what can i do?
Posted on Jul 11, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Emerson EWD2004 vcr eating vcr tapes
This is caused by mechanical problems in the VCR. Depending on the age and maker of the VCR, the take-up reel in the cassette is driven by a gear, a belt or a rubber wheel. This isn't happening properly in your VCR, so the tape is piling up inside. Given the low cost of replacement combo players (I don't think you can find just a VCR these days), it's not worth having repaired. You can expect to spend $60 to $100 on a repair for this kind of trouble, assuming there are even shops still willing to take the machine in.
Posted on May 13, 2009
Eating tape when I try and record or rewind tape
its sounds like the tape deck needs to be cleaned
Apr 13, 2010 | Canon GL2 Mini DV Digital Camcorder
Camcorder is eating tapes (or tapes are getting stuck)
Hi ; this problem is a miss alignement off your tapthern and you may replace the pinch roler assy
and a good head cleen up
and that should solved the problem garanty
hope thats will help have a nice day
Mar 04, 2010 | Canon ZR10 Mini DV Digital Camcorder
Your problem is a plastic belt that drives take up and supply reel. Most likely, you will not be able to relace it by yourself.
Dec 02, 2009 | JVC GR-AXM17U Camcorder
Eating up the tapes
Clean the rollers of the tape transport mechanism with spirit, failing which you can use whisky as well. just wet and squeeze the swab. dont have it dripping whisky all over and get it intoxicated.
Oct 04, 2009 | Video Cameras
Panasonic PV-DV102
there are 2 causes why your camcorder is eating up the tapes; either the tape head is dirty or there is a mechanical fault inside your unit (something might be misaligned that causes the film to be sucked in).
try to clean the tape head of your unit by using a tape head cleaner, it is like the tapes that you use with the unit but instead of a film there is a cloth like material inside that is used to clean the tape heads to avoid the film sticking to it
if the issue still persists then you should contact your manufacturer and set up a repair for the unit
Jul 02, 2009 | Video Cameras
Samsung Camcorder eating tapes
the roller inside your camcorder might have dust dirt. try to use camcorder's tape cleaner to clean it.
Jun 28, 2009 | Samsung SC-L906 Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
Oct 20, 2008 | JVC COMPACT VHS-C CAMCORDER
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Tape eating
unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Feb 04, 2008 | JVC COMPACT VHS-C CAMCORDER
Video Cameras Logo
143 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
