Question about Ps Car Audio & Video
Each sub woofer has a + and - post. They connect the same to the amp. However if the sub woofers have dual posts then the wiring changes
Posted on May 12, 2019
Hello Rayzberg, to connect a speaker to the PS Audio Stellar M700, you have to do it using a single pair of terminals, one positive (+) and the other negative (-)
You will connect the positive (+) speaker to one of the terminals (+) of the amplifier and the negative (-) of the speaker to the negative (-) terminal of the amplifier
In this way, a speaker will be connected to your PSAudio Stellar M700 amplifier
I hope you can connect, comment if you could do it
Greetings Franco Dosil
Hola Rayzberg, para conectar un parlante al PS Audio Stellar M700, tienes que hacerlo usando un solo par de bornes, uno positivo(+) y el otro negativo (--)
Conectaras el positivo(+) de parlante a uno de los bornes (+) del amplificador y el negativo(--) de parlante al borne negativo(--) del amplificador
De esta manera, estar? conectado un parlante a tu amplificador PSAudio Stellar M700
Espero que puedas conectar , comenta si lo pudiste hacer
Saludos Franco Dosil
https://www.psaudio.com/wp-content/uploads/2017/04/Stellar-S300-and-M700-Owners-Manual-Rev-A-V2.pdf
SOURCE: Denon Power AMPLIFIER
Try these links
http://ca.denon.com/ServiceCenterLocator.asp
http://www.fredsoundofmusic.com/denon_audio.html
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Posted on Feb 15, 2009
SOURCE: Kicker DS 650 Car Audio positive side/negative side
The positive side is always bigger [wider]is the easiest way to remember.....just like a Batt in a car.. The pos. terminal is larger.
Posted on Dec 26, 2009
SOURCE: pc connection
What you are proposing will not work.
You can EITHER use the Line inputs OR high level speaker inputs.
Using the line inputs, your L&R line level signals pass through the sub on their way to a stereo amp, then speakers.
Using the Speaker inputs, your L & R speaker cables connect from your amp (or PC speaker outputs) to the "Speaker input" terminals. The "Speaker output" terminals then connect to your speakers.
Posted on May 19, 2010
May 07, 2012 | Jl Audio G1700 Car Amp
Jan 26, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
Oct 01, 2009 | Jensen Car Audio & Video
Jun 20, 2009 | Soundstorm 500.2SL Car Audio Amplifier
Jun 05, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Mar 13, 2008 | Crown CE1000 2-Channel Amplifier
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Jun 06, 2007 | Verge VGA300M Car Audio Amplifier
61 people viewed this question
