Question about Brother Office Equipment & Supplies
How do free up the carriage direction lever on KG93 G-carriage on a brother G-Carriage
The G-carriage was not used very much so it is stuck
Posted by Joan Bittner on
KAUSTUBH GOEL
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
The CR setting on a Brother carriage is intended to free it from a jam. This is almost always effective.
Posted on May 12, 2019
5 Related Answers
Anonymous
  • 35 Answers
SOURCE: The cartridge carriage has stalled
If you can remove the dust from the paper lifting area with the help of petrol or ip (all the gararis) and reinstall that portion, change the encoder (which goes from the carriage) and clear the round encolder with the help of wet cotton. Greecing the cartridge park area and then check it. If you find any problem then contact me at [email protected]
Posted on Sep 19, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Cartridge is stuck in the wrong carriage...
only thin you can do is unforced the ink cart out
Posted on Jan 21, 2008
Anonymous
  • 151 Answers
SOURCE: paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Posted on Mar 10, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: printer carriage stall/stuck
  1. follow the steps below
  2. Reconnect the power cord to the back of the product.
  3. Press the Power button ( ) to turn on the product.
  4. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position
  • With the product turned on, disconnect the power cord from the back of the product.
  • Unplug the power cord from the power source or electrical outlet.
  • Check for any paper or objects that might be stopping the carriage. CAUTION: If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove any loose paper or obstructions found.
  • Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  • Close the carriage access door.
  • Reconnect the power cord to the product and to the power source.
  • Reconnect the USB cable to the product.
  • Load plain paper in the tray.
  • Posted on Dec 19, 2009
    Bob Wert
    • 123 Answers
    SOURCE: carriage belt replacement
    Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
    Posted on Apr 15, 2010
    Typewriter is stuck in uppercase; carriage not moving?
    get a typewriter repair shop involved - few typewriter repairmen are available anymore, as most folks use computers and word-processing programs for efficiency.
    Mar 24, 2018 | Brother Office Equipment & Supplies
    Have carriage stuck just to the right of centre on needle bed.
    Studio 322 Standard Gauge Knitting Machine?
    It might need disassembly and cleaning. Here are some other resources.
    Stuck carriage on a Brother video:
    https://www.youtube.com/watch?v=fgDQJOmg5DM
    https://garageknitstudio.wordpress.com/tag/knitting-machine/
    Do you have the Instruction Manual?
    Instruction Book SK 322 323 for Studio Knitting Machine
    Feb 05, 2015 | Sewing Machines
    Carriage is stuck on right side - can't even move it on rail - sprayed - still can't move
    can it be moved by using the carriage release levers on each side of the carriage
    Jan 13, 2015 | Smith Corona Office Equipment & Supplies
    Ink carriage is stuck on right side how do I make it move to but new ink into the printer
    Look in the left side of the printer, you'll see some wheels
    Shut the printer down and pull the power cord
    manually rotate the wheels until the little lever that block the carriage moves
    When the carriage is unlocked, you are free to move the carriage.
    Hope the Best
    ADCSFXworks printing center
    Oct 17, 2014 | Epson Workforce 520 Printer
    Attach carriage cable Brother EM 530 typewriter
    Has anyone any info on re-attaching the return cable?
    Apr 09, 2014 | Brother EM-530 Typewriter
    My spacebar wont move on the Brother Charger 11, (nor will the carriage move when I press any key) it seems like the shift key is stuck
    The carriage lock may be on. Either on the right or left side of the carriagle (little lever) push or pull up or down.
    Nov 02, 2013 | Brother Office Equipment & Supplies
    Cannot unlock the carriage
    There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
    Oct 29, 2011 | Olivetti Lettera 25 Typewriter
    Brother MFC-6490CW printer error unable to print 36
    Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
    Feb 09, 2010 | Brother MFC 6490CW InkJet Printer
    Brother GX 8250: my problem is with the carriage.
    Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
    Sep 08, 2009 | Brother Office Equipment & Supplies
    Carriage belt replacement
    Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
    425 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Norman  J Weimar Jr
    Norman J Weimar Jr
