When washer starts agatating cold water does not shut off. i have to wait for washer to fill then turn cold water faucet off otherwise washer runs over!
You have a leaking solenoid. It is failing to shut off. You'll need to shut off the water, unplug the washer, and disconnect both hoses (make sure that you mark the cold side at the washer, if it doesn't already have a mark). The blur plastic item that you hose screws on to at the washer is the solenoid valve. All it is is an electrically controlled valve that is either open or closed. Rewmove the back of the washer to gain aces to the solenoid valve. Take this part with you to any appliance parts supply house, and they can provide an exact replacement. Reassembly is the reverse of removal.
This isn't a difficult job. You can do it!
Best regards, --W/D-- please feel free to rate this solution - thanx!
Check the air pressure tube coming from the tub to the water level switch. It could be pinched,stopped up, or a hole in it. Check the water level switch. If tube and switch are good, replace the water valve.
