Question about AEG Washing Machines
Aeg lavamat 509n pilot light goes on intermittently. If the light isn't on the machine doesn't operate
5 Suggested Answers
Anonymous
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
Mukesh Kumar
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
Mukesh Kumar
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
jihadjawish
SOURCE: how do i reset a aeg oko lavamat 72620 washing
how to make reset to AEG OKO lavamat 61600
Posted on Nov 14, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: AEG Washing machine Oko Lavamat
The C9 on some AEG LAVAMAT models like the 71400, 72600,74620, 86720 and possibly others, is the same as the above F9, and is usually MOTOR BRUSHES WORN OUT. After replacement, you will need to clear the fault indication held in the PROGRAMMER PCB logic: With the Switch in the OFF position - Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin. Wait one or two seconds and all the indicators should illuminate. Then turn the control knob to OFF. All the indicators should go out. Then try and use your machine as normal. This should clear the C9 error code. If it does not -check there may be another fault present.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 29, 2011
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
Aug 24, 2016 | AEG Washing Machines
I need the user manual for an AEG Lavamat 1100 washing mashine
How to operate ano AEG LAvamat 1100 washing machine
Apr 13, 2011 | AEG Washing Machines
LAVAMAT MOTOR DOES NOT RUN
If there is water getting into the machine, then the motor, motor control unit, pressure switch, timer control and wiring harness must be tested. If the machine is a top load the motor coupler may replace the MCU of variable speed motors, that must also be tested then.
If cycle is not operating at all, with no water getting through the inlet check lid switch, door latch, inlet hose , inlet valve, membrane switch, Timer board and MCU if present.
Aug 02, 2009 | AEG Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG Lavamat 1000
hi
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
sami
Level 1 Expert
Vincent G
Vincent G
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
