Question about Stihl Saws
How do i take flywheel off stihl ts420 concrete saw
Posted by Adam Lampard on
1 Related Answer
H2_Brad
Brad
  • 425 Answers
SOURCE: stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Posted on Aug 25, 2012
Still ts420 concrete saw fuel line placement?
its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Apr 30, 2017 | Garden
Could someone tell me the difference between a Stihl TS410 and a TS420?
maybe here. http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-TS-410-420-Owners-Instruction-Manual.pdf
Mar 17, 2016 | Stihl Saws
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
How to adjust oil pump 08s concret stihl saw
There is no oil pump on a concrete saw, only on the chainsaw.
Feb 17, 2014 | Stihl Garden
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Stihl madel ts420 how to change air filter
Jun 22, 2012 | Saws
I purchased a used Stihl TS420 on ebay. When I unpacked the box the saw was missing the prefilter, filter and filter cover. The saw does seem to run ok. I stopped at a dealer and picked up a prefilter...
This was a problem with the original unit. They have since fixed this problem. There is a kit you can get from your Stihl dealer. It is a fuel tank/ air filter kit. You would have to replace the tank housing which is where the air filter bolts up to. You can have the dealer do it, or you can do it yourself. The kit is not cheap, but it will cure your problem. I've used a hacksaw to cut through the old bolts. Then you can change out the tank housing.
Apr 30, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Saws Logo
160 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
