Hello Christian, to establish a connection order, we will go from the microphone to Roland and Roland to the computer
first, you connect the Rode microphone to the Roland, through a cable with Cannon type connectors (XLR), the female connector to the Rode and the male connector to the Roland Mic input of the rear panel, you have to enable the Phanton key, in the front of Roland
Then you have to connect a USB to USB cable, from the USB connector on the back panel of the Roland to a USB port on your computer
This would be the connection sequence, then to use it, turn on the Roland first and then the computer and when you finish using it, first the computer and then the Roland
I send you the link to download the user manual, there you will find more options for operation
I hope you find it easy to arm and interconnect your Rode with your Roland and your computer
Greetings Franco Dosil
Hola Christian, para establecer un orden de conexi?n, iremos del micr?fono al Roland y del Roland a la computadora
primero, conectas el micr?fono Rode al Roland, a trav?s de un cable con conectores tipo Cannon (XLR), el conector Hembra al Rode y el conector Macho al Roland entrada Mic del panel trasero, tienes que habilitar la llave de Phanton, en la parte delantera del Roland
Luego tienes que conectar un cable USB a USB, desde el conector USB en el panel trasero del Roland a un puerto USB de tu computadora
Esta seria la secuencia de conexi?n, luego para usarlo, prendes primero el Roland y despu?s la computadora y cuando terminas de usarlo, primero la computadora y despu?s el Roland
te env?o el link para que descargues el manual de usuario, ah? vas a encontrar mas opciones de funcionamiento
Espero que te resulte f?cil el armado e interconexion de tu Rode con tu Roland y tu computadora
Saludos Franco Dosil
https://www.roland.com/global/support/by_product/vt-4/owners_manuals/21fab44d-24a9-428d-9623-9f58bc8db97a https://www.roland.com/global/support/by_product/vt-4/owners_manuals/7e0e40e5-4765-453e-b7e5-6b6eeb96a876 https://www.roland.com/global/support/by_product/vt-4/owners_manuals/00163e4e-893f-4528-a979-6d523149c23a https://www.roland.com/global/support/by_product/vt-4/owners_manuals/bb691ff4-8efe-4243-9d14-b316fcbb3fa7
SOURCE: Is there a 'front' to a Rode NT2 microphone when
I believe the front is the side with the response switch.
The Rode NT1A mic is a condenser mic and therefore it REQUIRES that "phantom" power be supplied by the mixer or amplifier. You will get only electronic "noise" if the mic is not receiving this power. Look up Phantom power to understand it. Essentially DC power is sent up the mic cable between the signal lines and the shield of the cable and is used by the electronics in the mic to amplify the signal from the condenser element.
