Question about Water Water Heaters
Atwood rv water heater no hot water no cool water
10 gallon some time water stop running on the hot water faucet
Posted by Leo perez on
ray gallant
    Top Expert:
  • Water Master
  • 68,569 Answers
THEY ARE INFAMOUS FOR BURNING OUT THE ELEMENTS . WATER NEEDS TO FILL TANK BEFORE POWER IS TURNED ON
Posted on May 02, 2020
3 Related Answers
motor1258
Mike Butler
  • 6674 Answers
SOURCE: Atwood DSI-RV Water Heater-6 Gallon: No hot water pressure....
Check for by-pass valve(s) on back in wrong position(s).
Posted on May 20, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: Have a 2005 coach w/Atwood
You need to check by-pass valve(s) on back of tank for proper position. You need cold open going in to bottom tank fitting, and hot open at top. If any valves in between those 2 lines via "T"'s, turn them to off position.
Posted on Oct 31, 2010
Tom Chichester
  • 56001 Answers
SOURCE: Atwood 10 gallon water heater has hot water on electric but will only run hot out of faucet for a few seconds and then go cold. Help?
The heating element may be breaking down.
Posted on May 21, 2016
Low or No Flow - Atwood 10 Gallon Elec, Gas, Heat Exchanger Type RV Water Heater
if good pressure on cold side check heater bypass maybe valve open partial or kinked hose
May 28, 2018 | Water Water Heaters
Hot water only runs for a few secons durning showers in rv
when you run out if hot water in the shower can you still get hot water in the othert fawcetts???
May 29, 2014 | RTO Atwood DSI-RV Water Heater-6 Gallon
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Have a 2005 coach w/Atwood DSI-RV 6 gal water heater. Gas lights, heater fires and gets hot, but doesn't transfer the hot water through the lines to the sink faucets. [email protected]
Oct 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Cold water runs through the faucet shower but no water at all through hot water side
If no hot water at any faucet, and your sure water in water heater is hot, check by-pass at back of tank for wrong positioning.
Jun 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
RV water heater problem: my water heater ignities, when I turn on the hot water faucet there is a steady flow of water but no hot water. The bypass valve is parallel with the cold water line. I can only...
The first question is this
From the outside of your RV is the water heater square or is it longer than it is tall?
If it is square it is a Suburban
If it is longer than it is tall then it is an Atwood
Forest River mostly uses Suburban
How long do you let the unit burn/run before you try the hot water? From a cold start it will take - depending on the outdoor temp. & the gallon size of your water heater, 15 to 30 minutes for the water to get hot.
If you have waited this long then I would suspect the bypass valve is in the wrong position
Sep 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water heater working fine but very little hot water coming out
alot of time those small units do not have a fast recovery rate so if they are on for a min or more they might start to lose temperature. if it's on demand especially in cooler climates it might not have enough power to heat it up and keep up with your demand
Jul 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water Heaters Logo
136 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
