Question about Konica Minolta bizhub Office Equipment & Supplies
My photocopier bizhub 210 is not supplying toner why
Posted by Masterpac on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Sir,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Does it say image unit or drum????????
Posted on Mar 22, 2020
2 Related Answers
Anonymous
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
Anonymous
  • 5 Answers
SOURCE: After a power surge it comes up with a C0501 malfunction code and shuts itself down
Turn ON the Power Switch with the Stop key held down. This also works on bizhub 162
Posted on Aug 10, 2009
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Help me to reset error codes c0070 & cof32 on minolta bizhub 210
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
I have a trouble code C-3727 showing on my photocopier konica minolta bizhub C353. What does that mean?
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Oct 06, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Is it possible to scan using 210 model scanner by network?
Yes, it is possible ti use Konica Minolta bizhub 210 photocopier as a network printer.For this simply purchase network card Model NC-502 for bizhub 210.
Dec 17, 2010 | Konica Minolta bizhub 180 All-In-One...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
