SOURCE: Samsung RS2630SH
I found a solution and it was so simple. What you have to do is hold down the power cool and power fridge buttons down for approx 10 seconds and that will reset the fridge and it should start right up. I did exactly that and it worked, AMAZING. I read this at another web sight and was told that The Manufacturers dont tell you (the consumer) about this secret because the service techs along with the part manufacturers would never make money from us (Go Figure). I hope this works for you too and if not, I cant imagine what else you need.
SOURCE: My fridge compressor stopped working. After
try to check your compressor resistance using ommeter or connect one test prod to terminal of compressor and one test prod to the body of your ref, if the pointer move or you read resistance it means your compressor burn out need replacement. or try to check your over load protector may be it damage.try to replace. the terminal of compressor is 1.2.3.connect the one test prod to 1&2 then read resistance then 2&3 then 1&3 these 3 terminal have different resistance these means your comp. is good.if good try to look fuses if damage replace it. observe unit. check your voltage supply may be it is higher than the rated voltage of your ref cause of burn out of your main board. or inspect the main board possible water leak the got wet the pcb boaerd
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
https://electronicshelponline.blogspot.com/
SOURCE: Can I replace Samsung LCD TV Main Board with similar one?
No you need the correct one.
Testimonial: "OK..."
Most samsung sets backlights will come on with the main unhooked, its how they're built, see if you have your PSON voltage when you push the on button it should be 3,3 or 5 volts depending on the model, if it stays at 0 then its the main, if you see that voltage replace the power supply
