Question about Hayward Pool & Spa
I have a new Hayward Ladybug, that i am trying to use for my above ground pool. I have an intex sand filter. And i do NOT have a skimmer.
I have what i would say is good suction up to the ladybug. But there is no suction under the ladybug, and will not move? get adapter on intake
Posted by Chris Vogler on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
David Shaub
  • 2976 Answers
SOURCE: Do I need a new sand filter psi gauge?
It wouldn't hurt to replace the gauge every few years, since it makes contact with heavily chlorinated water. They are available for less than $10.
Posted on Jul 07, 2009
nathan
  • 634 Answers
SOURCE: my pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
Posted on Jul 17, 2009
Anonymous
SOURCE: HI again - I can't get any flow from my INTEX 8111
there may be hair or debris stuck on the flow sensor OR you may have the input and output reversed. The input comes from the lower of the 2 holes in the side of the pool and hooks up to the middle area of the 8111. The output comes out by the electro cell and hooks to the higher of the two holes in the pool. The flow sensor can be found just inside the electro cell component. it should swing freely when you press it.
Posted on Aug 24, 2009
Anonymous
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
New intex above ground pool sand filter has no way to vacuum it
i do believe that intex sells a kit to vac the pool ,it includes a plastic scoop that fits in skimmer to go to bottom vac wand
me i saw a photo of kit and made one out of an old vinegar container i cut the bottom off of and a length of old hose from a wet /dry vac and i use that to run around bottom to suck up solids (gotta fill hose first before connecting it )
Jun 05, 2014 | INTEX Sand Filter Pump
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
How do I hook the pool to the filter and then to the pump
The outlet from the skimmer on the pool goes to the pump inlet (center part of the pump). The pump outlet goes to the filter inlet. The filter outlet goes to the return to the pool.
Jul 04, 2010 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
107 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
