Question about Mamiya Photography
Mamiya 645 pro doesn't fire without power winder WG401
Posted by Jayanta Bose on
1 Related Answer
Anonymous
  • 667 Answers
SOURCE: Mamiya 645 Super Replacement Parts
You can probably order direct from Mamiya, here is the contact info: Mamiya America
Posted on Mar 26, 2008
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
1helpful
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
2answers
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Mar 26, 2008 • Cameras
Open Questions:
Photography Logo
Top Mamiya Photography Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
