Have a set of xfit Bluetooth headphones....how do I reset them...they are vibrating and flashing whether they are on or off..
Xtreme xfit Bluetooth magnetic headphones
Posted by Sam Smith on
How do I pair a auvio Bluetooth wth iphone7
In general, you can press the power key for a while. If the light flashes, it means this method works and your Bluetooth headphones are ready. Then, back to your iPhone 7 or 7 plus settings, locate the device name of your Bluetooth headphones in Bluetooth Setting, and click it to connect
Feb 01, 2018 | Audio Players & Recorders
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How to reset the vibration
what do you mean, your headphone vibrates?
May 05, 2015 | Samsung HM1500 Bluetooth Headset
How to connect the headset to my phone
Make sure they have the same bluetooth stack, or at least a compatible stack.
To understand what it means, before you look up what stacks your devices have, look here:
Bluetooth stack
Apr 17, 2015 | hittime J-MALL Universal HV-800 Wireless...
How do I connect phone to plantronics
hi June,
I assume you are using a Plantronics wireless headphone? ensure your phone is on and Bluetooth is switched on in your phone settings.
hold the button on the headphone until the light starts flashing, if this does not happen ensure the headphone is charged. in Bluetooth options on your phone ensure your phone is set to "can be seen by other devices" and then use "scan devices" to find your headphone, if you see Plantronics in the list select it and press "pairing" this will then connect the headset to the phone. once paired, everytime your headset is on and Bluetooth is on, you need to just press the button on the headset and it will automatically connect to your phone.(as long as the headset name is not deleted from the Bluetooth list)
If your phone does not show in the headset in the Bluetooth list, keep the phone scanning and press the button on the headset to start the light flashing this is now causing the headset to search for the phone. once the headset shows in the phone list do as above.
I hope this was useful.
Nov 03, 2014 | Plantronics Audio Players & Recorders
How do i pair HP500BT with device
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Dec 28, 2013 | Technical Pro HP500BT Wireless Bluetooth...
How do you reset bluebuds x ?
Go into the Bluetooth settings of your device and remove the headphones (forget them)
Power on headphones; press vol + & vol - to enter pairing mode (alternating red-green lights flashing); press and hold vol + & vol - for 8 - 10 seconds until the light flashed orange; the headphones are now reset to factory defaults; pair the headphones to your device.
I have to do this every time I install an IOS update on my iPhone.
Oct 20, 2013 | JayBird Gear LLC BlueBuds X
LG HBS 700 wont stop vibrating
I fixed my Headphones that would not stop vibrating by leaving them ON until the Power drain out and they stopped vibrating. Then Turned them OFF, plug in the charger they began to Vibrate again but after the charge they Stopped Vibrating and have been ok ever since
Jun 14, 2012 | LG HBS-700 Bluetooth Headset
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
Lost instruction book
go on ur phone and go 2 bluetooth pairing. before u click pair, turn on ur headphones and hold the multi function( button w/ play button and phone symbols) button until flashes blue and red lights simultaneously. once flashing, enter and start bluetooth paring on ur phone. the code is 0000. enjoy using ur bluetooth.
Oct 18, 2008 | Insignia Bluetooth Wireless...
22 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
