Question about Hitachi Televison & Video
My Hitachi ac LED light 9 times blinking - Hitachi Televison & Video
Posted by Arka Roy on
5 Related Answers
Anonymous
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
Sparko1
Mark Wakefield
  • 167 Answers
SOURCE: power led lights blink 9 times, no power to
Call a good TV Tech and tell him about a Sony Recall on this TV concerning the S2 Thermal IC and Fuse.This causes the 9 blinks.It is an error code. S2 Thermal sensor IC and fuse
Posted on Jul 30, 2009
Anonymous
  • 788 Answers
SOURCE: hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Posted on Sep 28, 2009
orionsecurit
Gerry Sharpe
SOURCE: My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Posted on Jul 08, 2010
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: I have a 42PFP5332 which doesn't turn on. When plugging in the power the green led on the power circuit board turn for a few seconds and then blinks for 9 times. After that it blinks for 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 21, 2012
My hitachi inveter split ac green light 9 times blinking and ac not working
Get the model number of your mini split unit (on tag on indoor unit and outdoor unit) Google hitachi error codes. You should be able to pull up a code list for that unit. I believe it may be a communication problem between the indoor and outdoor unit. Possible bad connection of wire going from outdoor to indoor unit
Sep 14, 2018 | Hitachi Heating & Cooling
Hitachi splite ac red led bilnk 9 time why?
Here is a link to the blink codes if you ever need them again. It looks like you have a thermister that failed or the connection has become corroded. Your going to need to find it and check the connection or replace it.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.hitachiaircon.com/argws/html/helpingyou/en/AlarmCodes.pdf&ved=0ahUKEwiq-K__goLPAhXLPD4KHUARCwMQFggbMAA&usg=AFQjCNHYGrrhLgmTOJdADsQhCbYuVZGKkw
Sep 07, 2016 | Heating & Cooling
My hitachi ac disply led 7 times blinking red light machine not working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand.
http://electro-medical.blogspot.com/
Jul 10, 2016 | Hitachi Televison & Video
My carrier ac if i on the unit it will show green light 9 times blinking after off then 2 sec on green light again 9 times unit is not working
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If that dosn't work then you should contact a professional.
AC Repair West Palm Beach
Apr 26, 2015 | Carrier Heating & Cooling
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
RED LIGHT BLINKING IN HITACHI ICLEAN AC.. WHAT TO DO?
I was told the same thing that Dennis has posted by the guy who came to service the AC. So I think, it is ok as long as it blinks 9 times in a row and then repeats it after a brief pause.
Jun 08, 2012 | Heating & Cooling
Televison & Video Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
