Question about The Office Equipment & Supplies
How do i darken the priting via th printer tlp2824
Posted by Michelle Barnes on
ray gallant
    Top Expert:
  • The Master
  • 69,327 Answers
Contrast perhaps
Posted on Dec 12, 2019
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
How to download th software of th printer. Since i lost th driver cd. Please help me where can i download its software-
You get printer install software from the manufacturer. Usually for free. Be sure to download the correct software for your operating system, there have been lots of changes, and each one is different, no biggie, just pick the correct one.
You mention no brand name, or we could help more. Many printers SHOULD NOT be installed via "plug and play". Typically the printers lack functionality.
Just follow the directions exactly.
New things in printers are home network printers. They work similar to a printer hooked up to your machine, (meaning each computer can scan, rather than have to push buttons on the printer or go to the computer hosting that scanner, for example).
Dec 24, 2010 | Office Equipment & Supplies
I printed a picture I scanned the other day, today I am trying to print something in Microsoft word but it keeps printing the scanned picture. How do I clear that out and print from Microsoft?
The problem might be with the clipboard but this is really interesting problem. First try to delete the picture from your file that you are priting. If that is not the case try this:
From the upper toolbar pick Edit - Office Clipboard and then hit "Clear all" button.
I hope it helps
If not, contact me via my website
mike
http://www.mswordhelp.com
how to microsoft word; philosophy, tutorials, tips and tricks
May 22, 2010 | HP PSC 2210 All-In-One InkJet Printer
Stopped priting pdf's...how do i fix? It was
Not printing PDF files is not a problem with the printer if it prints everything else ok. The problem will be in the Adobe acrobat that you have installed, we have seen this type of problem before. This is caused by a corrupted file in the Adobe package. You need to go to Control panel and remove the Acrobat reader and install the latest copy, it is available for free from www.adobe.com You will need to be sure to uninstall the old version before you install the new one.
Buddy
Corporate Computer
May 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
I want my priting to be weeeear i can read it the
Increase the size of the letters before you print them. For instance, if you are using wordpad, before you write anything click on Format, then Font, and increase the number from 10 to 12 or higher. If you are cutting and pasting to Wordpad, increase the size of the font before you paste. If you are printing directly from a web page, click on view and zoom in before you print.
Oct 03, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Zebra TLP2824 Printer Problem
You could also send the EPL command.
^default (use the DOS editor)
or
Download latest firmware file from zebra websiten copy it to printer using dos command. This will automatically reset the 2824.
Connect to a PC via parallel port.
copy filename.prg lpt1:
Jan 14, 2009 | Zebra Eltron LP 2824 Thermal Printer
Add prite to computer
You can download the driver for this machine from http://www.printcountry.com/drivers/brother_drivers.asp (other sources may available if you search on the internet) once you have the driver downloaded simply install it and you should be good to go.
Sep 18, 2007 | Brother MFC 1950MC Printer
35 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
